Over heating issue, need help.
Old Aug 30, 2010 | 11:44 AM
LT1's Avatar
LT1
Default Over heating issue, need help.
I have a 95 Honda Accord 2.2L vtech. I notice the temperature going up lately use to run real cool now the temperature reads above the half way mark. My coolant reservoir is getting filled up. Top hose is hot, bottom hose is cool. I replace the Coolant its new, all new hoses and i don't see any coolant leaks.
I wanted to get some ideas from everyone before replacing thermostat or radiator cap.
Old Aug 30, 2010 | 12:21 PM
redbull-1's Avatar
Default Re: Over heating issue, need help.
If your bottom radiator hose is cool, this may be indicative of the thermostat not opening.
Even though it may be the thermostat, also check that the fans are operating. The radiator fan is the right side one (passenger side). Unplug the connector plug on the thermo-switch on top of the thermostat housing. Thermostat housing is near the back of the engine, connected by the lower radiator hose. Jump the connector thermo-switch plug with a wire or small paper clip. Then turn key to 'on', the fans should turn on. If not, it could also be a bad fan motor.
Old Aug 30, 2010 | 01:36 PM
F20B_accord's Avatar
also if one is hot and the other is cold it could be a clog in the actually radiator
Old Aug 30, 2010 | 06:16 PM
LT1's Avatar
LT1
Thanks for the input, ill take the thermostat off and test it.
By the way, the fan works fine, i hear it running all the time because the temperature is up.
I doubt the radiator is clogged ive flushed it and put new coolant in.
Old Aug 30, 2010 | 10:30 PM
holmesnmanny's Avatar
The thermostat is an 8.99 part, and it's such an important part of your cooling system, if you haven't changed it since you can remember, it's wise just to swap it out.
Old Aug 30, 2010 | 11:08 PM
bseriescrxsi's Avatar
to the OP for future reference when your doing any interval maintenance you should
check:
rad cap
pcv valve
Replace:
thermostat
and that is only at a bare minimum
Old Aug 31, 2010 | 04:02 PM
poorman212's Avatar
And you bled the cooling system after the work? Has this idle been funny. Trapped air in the cooling system can cause issues as well. Be sure to bleed the system after opening it up.
Old Aug 31, 2010 | 05:12 PM
LT1's Avatar
LT1
Awesome yall, i replaced the termostat and bled the air out of the system. The temperature is running really cool below half way on the gauge. Looks like that was the problem.
And ya i haven't ever replaced the thermostat as long as i remember. Since i was in there thought i replace air filter, rad cap, pcv valve too. Runs awesome thanks for all your tips.
Im gonna start another thread for my other problems lol (my speedometer gauge stops working randomly, abs light on, air bag light on).
Old Sep 12, 2010 | 08:50 PM
jose ray's Avatar
any one on line...??????????????????????????????????????????? ??//
Old Sep 12, 2010 | 10:11 PM
speedo problem is due to a malfuntioning circuit board on the speedo unit
Old Sep 13, 2010 | 09:26 PM
LT1's Avatar
LT1
Is it possible to fix the circuit board? Is it a common problem?
Old Sep 14, 2010 | 04:18 AM
nus_dogg's Avatar
I don't see too much problems with the circuit board.
CHANCELLOR12
Oct 9, 2015 07:16 AM
thechineseone
Nov 28, 2008 11:26 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
Twistedframe
May 24, 2007 08:26 AM
honda4life4456
Nov 16, 2003 06:20 AM
