Weird rattling noise
Old Aug 30, 2010 | 11:18 AM
JDM215's Avatar
Default Weird rattling noise
So when i let go of the clutch a weird rattling noise comes from the tranny but when i step on the clutch again it goes away i was told it was the throw out bearing. so im just coming on here to see what you guys think it is.
also when i start driving a weird rattling noise comes on as i start moving itll go away when i stop but when put it in gear and move or just start coasting itll make a weird rattling noise like the axle isnt in all the way but i checked and it was in there
can you guys help me out this is my only car that i can use to drive to and back from school.
its a d16y7 with stock everything except intake and exhaust
Old Aug 30, 2010 | 01:40 PM
C uR eX's Avatar
Default Re: Weird rattling noise
IT 1 of 2 things....
Your throw out bearing is no good or you transmission differential bearing (2). i have the same problem with my VX tranny and though that is was the throw out bearing so i decided to change that (i was gonna change my clutch anyway). After changing the clutch and throw bearing still have the same problem but less of a noise.
So i swapped with an extra tranny i had lying around and that solved the rattling noise. i on;y swapped the tranny because i didn't have time to take the tranny apart and replace the bearing or anything. But i will eventually buy a rebuild kit and do an over haul on the VX tranny one of these day,.
Old Aug 30, 2010 | 05:34 PM
JDM215's Avatar
hopefully its just the throwout bearing times are hard and i am brokee lol
shermanyang
Dec 1, 2012 11:24 AM
4gnhatch
Jun 24, 2005 06:53 PM
SJR
Apr 21, 2005 06:56 PM
Emshhh
11
Feb 2, 2005 11:10 PM
