Hot engine stalling out
Old Aug 29, 2010 | 05:24 PM
Nkietzer's Avatar
Default Hot engine stalling out
I just recently bought my first honda car. It is a 93 accord 10 anniversary edition. I have replaced all of the fluids, new spark plugs, wires, and air filter. I have noticed a problem that did not occure when I test drove the car. When the engine is hot you put it in gear to idel, out of a parking spot, sometimes it has the tendancy to die. I am wondering what may be causing this to happen. I have read on the site that it may be a bubble in the coolent, a bad or dirty iacv, or the fitv. I am not sure where to start to figure out this problem. Any help would be great, because I drive around 2 small kids in south texas heat. Thanks!!
Old Aug 29, 2010 | 07:31 PM
F20B_accord's Avatar
Default Re: Hot engine stalling out
hmm could be your idle speed does it sound like your idle goes low before this happens? or how does it go just conks out??
Old Aug 29, 2010 | 08:33 PM
htekken's Avatar
hmm, right after you put the car into gear do you see the idle drop and go back up? and then sometimes it will go low enough to where the car does end up stalling?
Old Aug 30, 2010 | 02:23 AM
joe_accord23's Avatar
it only does this when its hot?, also, does it go low and back up to 700 rpm?
Old Aug 30, 2010 | 06:58 AM
Nkietzer's Avatar
The idle speed drops to low and it stalls out. It has only seemed to happen after a long hot trip around town in 100 degree weather. It is an automatic tran. as well if that makes a difference.
Old Aug 30, 2010 | 08:51 AM
htekken's Avatar
ok then i could only guess its an idle issue. i would just do what you read anyway. clean out the iacv, fitv, then go ahead and do cleaning maintenance on the egr valve, egr ports, and throttle body.
this is what i gathered so far since im having idle issues as well right when putting car in reverse gear.
Old Aug 30, 2010 | 09:03 AM
King's Dyno's's Avatar
If you were going down the tuner road you could chip it and adjust the idle dependant on the temperature, ecu's normaly dictate a 1000ish idle for start up and 750ish idle for running temp,(AIC Compensation) yours sounds as if its not to sure what to do in the heat and is throwing the huff!
Worth a shot, and an idea if your planning to map at a later date...as in 'well im goin there anyway' hell, id even send you the software to get it done
Old Aug 30, 2010 | 03:01 PM
royalaccord92's Avatar
I'm surprised no one has said this but I would check your main relay if it only happens when its hot. Doesn't have anything to do with the idle I know but they always go out on 90-93 accords and usually only show symptoms when it's hot.
Old Aug 30, 2010 | 08:50 PM
redbull-1's Avatar
The stalling may be caused by a bad igniter. See this link:
http://techautorepairs.com/ignition.html
It probably is not the main relay, as a bad main relay would cause no-start problems when hot and not the stalling, etc.
Old Aug 30, 2010 | 08:56 PM
uberEFtuner's Avatar
I would have to say bad distributor. Get one with a lifetime warranty.
Old Aug 30, 2010 | 09:11 PM
redbull-1's Avatar
The igniter is in the distributor. It up to you whether you want to take apart the old distributor & replace just the igniter or replace the whole distributor, if that turns out to be your problem.
Old Aug 30, 2010 | 11:16 PM
htekken's Avatar
do ppl usually replace the ignitor and ignition coil when doing a major tune-up? for the distributor i was gonna replace the cap, cap gasket, rotor, oring, n spark plug wires.
Old Aug 31, 2010 | 06:04 AM
Nkietzer's Avatar
So to start, I am going to do a real good cleaning of the iacv, tb, and fitv. After that I am going to see out the the car reacts. I am saying that only because I just replaced the cap and rotor.
Old Aug 31, 2010 | 06:57 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Does the problem go away if you turn on the AC? If so, check the thermostat.
Old Aug 31, 2010 | 09:21 AM
Nkietzer's Avatar
No the problem seems to only occure when the AC is running.
Old Aug 31, 2010 | 09:27 AM
GoLowDrew's Avatar
Old Member
25 Year Member
I'll just share my story and may or may not apply. The thermostat was bad. So the fan would kick in at the wrong time. It works, just at the wrong time. Therefore, causing the engine to overheat and the computer shut down the car.
So when I turn the AC on, it seems to work ok because the fans was constantly running, instead of cycle On-Off.
So later I had a guy "hard-wire" it so the fan was on all the time. It solved the problem, because we didn't want to "fix it."
Just throwing it out there. Good luck.
fessup
Honda CR-V & Element
Dec 7, 2017 01:11 PM
bronzecouch
Dec 27, 2009 01:13 PM
hellakornhaus
Apr 5, 2007 12:53 PM
jaycapz
Sep 1, 2004 02:43 PM
hahnchen
Mar 11, 2004 04:13 AM
