1986 Accord High Idle @ Start up and engine dieseling?! -- HELP!!!!!
My wife and I bought a 1986 Accord DX, with only 93,xxx on the clock. I have been working on getting the thing running right for about 2-3 weekends in a row. I have fixed everything except for the high start-up idle (2500-3000 RPM). I have read that this is the automatic choke. However, I have a hard time believing that is the problem/issue. Because I drove the car about 20-25 miles, turned the car off for about 10 minutes, and upon restart - the idle still jumped to nearly 3 grand. The choke should only function when the engine temp is cold, right?! Before anyone says this, I have already adjusted the Idle Speed Screw. Do I just need to adjust it out even more? Is it as simple as that?
Also, the engine will diesel SOMETIMES. It seems to only do this when I start the car for about 3-5 minutes, and then turn of off. However, when I go for a test drive, say for 10-15 miles, it usually shuts right off. I have fixed the idle speed and I have re-timed it 3 different ways (in gear, in park, and with vacuum lines off of distributor). All of which didn't really do a difference.
If anyone could shed some light, I would greatly appreciate it!
-Kornhaus
-Kornhaus
Re: 1986 Accord High Idle @ Start up and engine dieseling?! -- HELP!!!!! (hellakornhaus)
Sounds like it's sucking air into the intake from somewhere. Check all the vacuum hoses for drying and cracking. If they all look good, hit the intake gasket areas with a spray bottle of water. If the idle drops when you spray a certain area, the water is temporarily restricting the air flow through the leaking spot. Or you might have a fast idle valve that is malfunctioning if your engine has one.
jkrueger2020
06-18-2012 05:01 PM
