deltegra help please?
Old Aug 29, 2010 | 03:20 PM
deltegra11's Avatar
Default deltegra help please?
hi there everyone, i have a 95delsol in the works with the front end switch with a 95tegra front. i have everything done! but the dam fenders!! an i need help with them very badly.. i have been working on them aaalll ddaaayyy lloonggee an trashed three fenders now an some money so i quit to find info on where to cut them an some pics or anything. but... i cant find sh*t on that.. so if any one can help with pics of the cuts on the fenders or anything on how to do the fenders please help asap!!! thank you all for the help!!!
Old Aug 29, 2010 | 06:13 PM
ManBearPig4silly's Avatar
Default Re: deltegra help please?
I'm trying my hardest to be nice.
has this even been done before? I highly doubt you are going to find any reliable info on it. Post some pics I guess. I can't see where it would be that difficult. It's just a piece of steel in a shape that you need to change into another shape. Are you shortening the front end to match the length of the original delsol front clip? If so the fenders sound easier than the hood....
Old Aug 29, 2010 | 06:39 PM
overvolting's Avatar
useless without pics
Old Aug 29, 2010 | 07:08 PM
deltegra11's Avatar
yes it has been done before search on google there r pics there.. the hood was simple all i had to do was oval out the holes on the hinge that goes on the car an i got the hood on an to line up with front bumper. the front clip is the same size as the delsol started but jut with the cores of the integra an in that the front clips of both integra an delsol r the same just not the fender shapes an the fender sizes betweenthe doors. an thats what i soon fond out after going throw a couple fenders cause i had to many cuts in them to make them look good.
Old Aug 29, 2010 | 07:12 PM
deltegra11's Avatar
Old Aug 29, 2010 | 07:14 PM
deltegra11's Avatar
Old Aug 29, 2010 | 08:13 PM
o_0
I think we meant pics of your project, but those do help as well bravo.
Old Aug 30, 2010 | 04:57 AM
deltegra11's Avatar
ok i will have to put some up on here tonight on this post so please look back on this tonight an i will have them put on here like around 9pm est.
Old Aug 30, 2010 | 05:24 PM
deltegra11's Avatar
Old Aug 30, 2010 | 05:26 PM
deltegra11's Avatar
Old Aug 31, 2010 | 04:10 AM
90Rexx's Avatar
cut the fender about half way up the wheel well, and weld on the front half of an integra fender to your back half of the del sol fender.
Old Aug 31, 2010 | 05:19 AM
what 90rexx said
Old Aug 31, 2010 | 07:23 AM
deltegra11's Avatar
Ok I tried that but I have a gap still an I'm not sure how to fix that.... an I'm not taken it to a body shop when I know I can do the work
Old Aug 31, 2010 | 07:25 AM
DESTROYER's Avatar
Where is the gap? I guess we need update pictures to see for ourselves what needs to happen.
Old Aug 31, 2010 | 02:45 PM
the black fender on your car is the delsol one right? I'm going to scratch my first advice(or just modify it) provided the radius of the wheel wells are about the same I would cut the delsol fender in a straight line from top dead center of the wheel well to a point maybe 2-3 inches forward of the back corner of the hood. Do the same thing the to the teg fender and bust out the bondo to transition all the lines. Its going to be easier to keep the thing straight and figure out the transition than if you were to just chop it in half vertically.
hint. cut the teg fender big so you can slip it behind the delsol fender(that is already bolted up) so you can get an idea of how it's going to line up before you figure out your final cut on the teg fender. Then just trace it and cut it.
Personally, I would just lap them a little, stitch weld them together and smooth it out with bondo. Butt welding that stuff is a bitch and a half(this is coming from a professional welder).
Note: I do not approve of your project but yet i'm giving you advice....**** i'm getting old.
Old Aug 31, 2010 | 04:51 PM
deltegra11's Avatar
no no the fenders on the car are all sol fender an need help on where to cut cause everyones saying front of fender but as i can see by thes pics even if it wasnt at my house that wont work.
Old Aug 31, 2010 | 04:55 PM
deltegra11's Avatar
yea i tried the cut half an half an well that didnt work out well cause of the hood gap from the sol fender to the hood plus the shapes r off a good bit in the center of the fenders
Old Sep 1, 2010 | 02:59 PM
I know thats why I suggested the cut(on the delsol fender) starting at the center of the wheel well back to the corner of the hood.... that way you have the entire top edge of the teg fender to line up to the edge of the hood. You have the front end of the teg fender to line up with the bumper. You have the rear end of the delsol fender to line up to the door. then you have a cut splitting the fenders at an extreme angle through the contours so it will be easier to keep straight and blend together.
If I've lost you I'm sry.
Old Sep 1, 2010 | 08:35 PM
deltegra11's Avatar
ok i got u now.. but i think i have found my answer to my own question take a look at this its a civic but there fenders r the same shape other then the fronts at the bumpers so i beleav this is my answer!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/integra-front-end-swap-2476540/
Old Sep 2, 2010 | 05:28 PM
yep that looks like it works. Looks like the profile in that area isnt that to far off between the fenders.
Old Sep 8, 2010 | 08:50 AM
deltegra11's Avatar
I know that's what I am hopping
deltegra11
Paint and Body
37
Dec 20, 2011 07:53 AM
deltegra11
Paint and Body
21
Sep 8, 2010 08:42 AM
92 CiviC H.B
Jan 25, 2008 10:11 PM
eleagueldr
Jan 4, 2006 01:30 PM
