Beaks Lower tie bar
Hi I ordered a used tie bar but it didn't come with the bolts. Where can I order these bolts and what size are they? I know they need to be 10.8 steel grade but i don't know the size? Can anyone point me in the right direction. I tried doing a search but couldn't come up with anything. My car is an ej2 (94 civic dx) So it didn't come with sway bars or LCA's that have bolts for the sway bars. So what other mods would you recommend to increase handling? Thanks
Firs off i would sell the beaks tie bar. They dont add anything besides "bling"
The frist thing i did with my dx is went with skunk2 10k front and 8k springs, then i added 99-00 si sway bars front and rear.
What does your car currently have done to it? Suspension, and tire wise?
The only suspension mod that is done is lowering springs. So i need EX front lca's and Aftermarket rear Lca's. I also plan on getting strut bars for the front and rear as well. As for sway bars i'm not sure what size or kind to get. I'm looking to make my car better at going threw turns.
A ex sway bar would work good. You would need there lca's to use the sway bar.
No, you dont have to have aftermarket rear lca's, if you want them go for it.
Integra rear lca's and some eg lca's will work just fine.
zippo1130
15
Jan 15, 2008 07:45 PM
