1993 Honda Civic won't crank
Old Aug 29, 2010 | 02:05 PM
campj's Avatar
Default 1993 Honda Civic won't crank
Hey, I am new to this site. I have a 1993 Honda Civic. I was coming up a hill, low on gas and it started to skip, figured it wasn't getting gas because one it was low, and two I was coming up a hill. Got it home on fumes. Let it sit for a week. Put gas in it and now it will not crank. It will turn over, and if I leave the starter engaged via leaving the ignition turned, and give it gas, the rpms will shoot up, however, as soon as I let go of the key, everything shuts down. Will not crank as soon as I let off the key. Have I burned my fuel pump out or pumped air into the fuel filter? I know where the fuel filter is, but where is the fuel pump? Can I access the fuel pump? Or do I need to take it in? How can I tell if the fuel pump is still working? Thoughts?
Old Aug 29, 2010 | 03:10 PM
CRX Si69's Avatar
Default Re: 1993 Honda Civic won't crank
fuel pump is in the gas tank. when you turn the key on can you hear the fuel pump prime?
Old Aug 29, 2010 | 05:05 PM
H22AFerio's Avatar
Sounds Like a burnt up fuel pump to me.. like campj said just listen for the pump to prime.you can just roll up your windows and turn the key on but do crank it over and you should hear the fuel pump buzz and then shut off. I try to keep at least a 1/4 tank in there to keep the pump from suckin up any of that gunk in the bottom of the tank. Got my fingers crossed, Good Luck!
Old Aug 29, 2010 | 05:07 PM
EJeff8's Avatar
Take the backseat bottom off and bam, fuel pump.
jastonian106
Feb 28, 2015 09:03 PM
dudeomega2000
Jul 13, 2009 08:15 PM
EKSedAndy
Nov 12, 2007 10:22 AM
Shaun
Jun 22, 2006 03:24 PM
gokuson
Jun 30, 2002 06:14 PM
