Is the input shaft from b16 and b18 trannys interchangeable?
Old Aug 29, 2010 | 08:58 AM
SoFresh1189's Avatar
Default Is the input shaft from b16 and b18 trannys interchangeable?
does anyone know if the input shaft between the b16 and b18 trannys are interchangeable? and if its better for performance?
Old Aug 29, 2010 | 09:24 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: b-series tranny question
better performance??? no, it would be a complete waste of time
You could change the final drive of your existing tranny if interested in a different gear ratio
Old Aug 29, 2010 | 09:31 AM
ok well im having a transmission prob i think is the input shaft. it goes in to every gear fine but when i let off the clutch it goes nowhere.
id rather just replace the input shaft if i can.
Old Aug 29, 2010 | 09:44 AM
Deetz's Avatar
Crazy Honda Guy
could be as simple as a throw out bearing....why not take it to a Honda dealer, where a real tech can check it out for you?
Old Aug 29, 2010 | 09:50 AM
because the car doesnt move and im not paying to have someone look at something i can fix. nor can i afford to tow it if i wanted to.
also a honda dealer wouldnt touch it because its a swap.
if it was a throwout bearing would it cause this prob?
Old Aug 29, 2010 | 10:09 AM
b20hatchek's Avatar
by law they can't deny your car for repair, and if you have insurance you may have tow on your coverage they for your insurance company will cover it
Old Aug 29, 2010 | 10:22 AM
i would still rather do it myself.
Old Aug 29, 2010 | 10:24 AM
b20hatchek's Avatar
just saying
Old Aug 29, 2010 | 10:37 AM
that doesnt really help.. does anyone know if the input shafts are interchangeable?
assuming it is the input shaft.
Old Aug 29, 2010 | 10:44 AM
WeakSauce92's Avatar
From what I hear almost daily: D to D, B to B, H to H, K to K.. lol I'm sure it will work.
Old Aug 29, 2010 | 01:13 PM
lol ok ill give it a shot
Old Aug 29, 2010 | 01:18 PM
Dontoh's Avatar
cuse, mad close haha. but for sure, figure out 100% whats wrong with it first before you start tearin **** about.. you ever roll up to erie blvd?
Old Aug 29, 2010 | 01:28 PM
yeah occasionally i have the black del sol but im working on a 91 hatch with a b18motor/b16tranny swap
Old Aug 29, 2010 | 01:48 PM
94EG8's Avatar
Seagull Management
Its in all likelyhood not the input shaft, it would literally have to be broken in half or the splines for the clutch would have to be sheared off. This tranny, is it in the '91 hatch? What did you use for a clutch? B16 cable trannys and '90 - '91 integras use a small spline input shaft, '92+ use the larger style. '92+ clutch on small spline tranny = clutch thats not splined to the mainshaft, which also leads to no movement.
Old Aug 29, 2010 | 01:58 PM
what else could it be if its not the input shaft?
someone i know threw around the idea that a puck might have broken off but i doubt that. its an act stage 3, 3-puck clutch
Old Aug 29, 2010 | 02:47 PM
great info!
Old Aug 30, 2010 | 08:42 PM
it was actually the input shaft.
Old Aug 31, 2010 | 02:55 AM
94EG8's Avatar
Seagull Management
Broken or stripped splines or?
Old Aug 31, 2010 | 07:59 AM
sorry that wasnt me that posted that, i left my account logged onto my buddys computer so im not sure who posted it. ive been lazy and havent even gotten the transmission off yet but i seriously am starting to doubt its the input shaft because of how hard it would be to break the splines or strip them.
Old Aug 31, 2010 | 10:07 AM
94EG8's Avatar
Seagull Management
Probably should have asked this earlier, but does the speedometer move when you let the clutch out? If so then its an axle problem, if not its a clutch or transmission problem.
Old Sep 1, 2010 | 12:46 AM
If only the cv shafts werent already out and had more than two bolts left until the trannys cracked I wish i would have thought about that now... But the whining noise definitely sounds like its coming from the tranny no doubt about it. A little bit better of a background. B18a. stage 1 brian crower internals, lightweight underdrive pulley and flywheel. stage 3 ACT 3 puck clutch. Cable driven JDM J1 transmission. Im the owner of the car, i was down shifting into second to slow down to a stop sign, foot slipped off the clutch, the cars got a **** ton of snappiness to it so i popped the clutch, heard a loud POP, then realized no matter what gear i was in, i wasnt moving. Never thought to check the speedo in all honestly, stupid me. You can hear something rubbing against the clutch and when you press the pedal to the floor it sounds absolutely awful, it wasnt any grinding or crunching noises, just loud whining rubbing. As soon as i get the bitch pin off the shift linkage I'm going to take off the last mount bracket and cracking it. dun dun dunnn.
Old Sep 1, 2010 | 12:47 AM
and obviously complete exhaust, headers to tip with the aem intake and short throw shifter.
sportsman1539
Transmission & Drivetrain
Dec 26, 2013 07:33 AM
oneslowstd
Mar 11, 2009 10:51 PM
Pengo
Jun 20, 2003 08:52 PM
XEF-9X
Aug 1, 2002 06:52 AM
