D16y8 knock sensor question
Old Aug 29, 2010 | 07:40 AM
handa's Avatar
Default D16y8 knock sensor question
I got one plug left on the wiring harness--it is a single red with blue stripe wire prong. I think it is the knock sensor plug. Where is the knock sensor on the d16y8?
I've been researching and see mixed information. But I believe #2 is where it's at. A lot of people say it's at #1. But at #1, I have three d16y8 blocks with this plug--looks like the end is broken off (how could three blocks have this?). So that can't be it. #3 is oil pressure for sure.
Any ideas?
PS. Don't mind the blown block in pic.
Old Aug 29, 2010 | 08:16 AM
SIRIUS VTEC's Avatar
Default Re: D16y8 knock sensor question
the knock sensor would be number 1 and as far as i know from the d16y8 i just put together it's a two wire connector, not just a 1. In fact im certain i broke one last week and i remember it vividly.
Old Aug 29, 2010 | 08:18 AM
number 3 is an oil pressure switch. I had the same pic as u did.
Old Aug 29, 2010 | 08:21 AM
EJeff8's Avatar
Knock sensor goes directly under the second IM runner. Like not a mm under it is the knock sensor thread.
Old Aug 29, 2010 | 08:23 AM
Holy crap bro, you're right that connector in between my fingers is the one and i can see a red w/ blue stripe peaking out.
the green connector is the one i broke..on ur pic it looks like yours it missing too.
Old Aug 29, 2010 | 08:26 AM
idk why i remember it being two wires but that may have been the number 3 on ur pic. the pressure switch
Old Aug 29, 2010 | 01:48 PM
handa's Avatar
Sirius, it is confirmed. #1 is the knock sensor (single wire). #3 is the oil pressure. #2 is optional tap if you want to do some custom stuff to your motor.
I even took out the #1 piece and it looks similar to this:
Old Aug 29, 2010 | 04:47 PM
HondaPartsHero's Avatar
Technical Hero
#2 is for draining the coolant from your engine
gsumano
Northern California (Sales)
Jul 25, 2008 02:05 PM
jr000
Aug 30, 2007 09:50 AM
redpeppers
Sep 15, 2005 06:42 AM
y2ks2k
May 11, 2005 02:29 PM
FormulaEJ8
Feb 8, 2003 07:59 PM
