IACV problem
hey guys i put a f23a1 out of a 98 accord into my 90 accord and i got it running but the idle is jumpy because the IACV isnt hooked up. and the main difference in wiring is the IACV on the intake manifold because it is a 3 wire prong instead of the 2 wires from the f22. is there a way to make my 2 wire setup work for it or no?
sup man i had the same prob with a 2001 h23a vtec. what i did is, they sell an aluminum block plate that blocks the big hole's that it has and the plate it self has two holes, it screws into the manifold and then u put the two wire sensor on top of the plate and walla u have a two wire sensor back.
BlackTrax makes them;
http://www.blacktrax.net/products/In...r_Adapter.html
Looks pretty simple. Could be an easy DIY if you have a drill/drill press and a piece of aluminum.
PrecisionH23a
Apr 20, 2008 02:10 PM
Pfieff
Dec 2, 2003 09:47 AM
