IACV problem
Old Aug 28, 2010 | 08:29 PM
scottypippen147's Avatar
Default IACV problem
hey guys i put a f23a1 out of a 98 accord into my 90 accord and i got it running but the idle is jumpy because the IACV isnt hooked up. and the main difference in wiring is the IACV on the intake manifold because it is a 3 wire prong instead of the 2 wires from the f22. is there a way to make my 2 wire setup work for it or no?
Old Aug 29, 2010 | 02:17 PM
nicolas1320's Avatar
Default Re: IACV problem
sup man i had the same prob with a 2001 h23a vtec. what i did is, they sell an aluminum block plate that blocks the big hole's that it has and the plate it self has two holes, it screws into the manifold and then u put the two wire sensor on top of the plate and walla u have a two wire sensor back.
Old Aug 29, 2010 | 04:46 PM
oh nice thanks man. where can i buy this plate at? cuz i need this to run right very soon lol
Old Aug 31, 2010 | 12:33 PM
bump
Old Aug 31, 2010 | 12:42 PM
GhostAccord's Avatar
BlackTrax makes them;
http://www.blacktrax.net/products/In...r_Adapter.html
Looks pretty simple. Could be an easy DIY if you have a drill/drill press and a piece of aluminum.
RPM JDM
Nov 2, 2009 06:14 PM
PrecisionH23a
Apr 20, 2008 02:10 PM
Ls-Turbo
Oct 25, 2005 04:38 AM
Pfieff
Dec 2, 2003 09:47 AM
