crome says recording but cant find anything recorded
hello im using crome pro and aem uego crome says recording at bottom right but nothing gets recorded also my a/f ratio stays at like 20 or 21 in the right hand of the screen my wideband reads good and it is hooked to D14 or d15 whichever is the oxygen sensor reading
With your car running are you able to read and see all of the sensor data changing on the right hand column?
In the bottom left corner have you clicked on the Live tuning, smart tracking buttons? Have you tried clicking on the save datalog button at the end of the run/datalogging session? It is also located in the bottom left corner of the screen.
Just to make sure.. Did you set your 'tuner logging' to read the AEM's output rather than on the 'stock narrowband' setting???
yea everything else does change but a/f stays around 20 but the wideband guage seems to be correct i do have the live tuning button engaged and smart tracking
i did also change the settings for aem i will check it all out again and get back to your guys later im in the middle of getting my other engine in my other car which i will need this stuff for too
got wide
Engine Management and Tuning
Sep 20, 2008 06:20 AM
