hook wideband up to safeguard or voltmeter
Im curious bout hooking up a wideband sensor to a js safeguard monitor. The sensor lets off a voltage right? like the aem? So how would it be possible to hook it up to the display for the safeguard? It would be pimptite to get accurate readings through the safeguards monitor.
Re: hook wideband up to safeguard or voltmeter (joek84)
Narrow band sensors put out 0v when lean, and 1v when rich. Wideband sensors put out 5v when lean, and 0v when rich (I think).
I think the AEM WB can convert the signal to look like a narrow band output, so the factory ECU can run off the more accurate WB.
Re: hook wideband up to safeguard or voltmeter (John at J&S)
Cool thanks. I just found this on bout the aem:
"This system is offered in both single and dual channel modes and is the most affordable UEGO controller available. The AEM wideband UEGO controller has a very low current draw and features both 0-5v and 0-1v calibrated outputs to mimic the factory narrow-band sensor, eliminating the chance of a factory computer issuing a trouble code."
So I can use just the aem wideband and hook it up to the js monitor and get accurate results on the bar meter, right, or any other a/f meter for that matter?I wanna use the js meter because it's got actual numbers rather than a sweeping meter. What's the difference between the single and dual modes? I've got a 2k gsr but im converting to obd1 using a p72. Is it tru that with obd1 i only need one o2 sensor? can it be the aem one alone? If so which o2 sensor should i get rid of when i get my header and exhaust upgraded? Thanks again
Modified by joek84 at 6:29 AM 10/1/2003
I've got more to ask. What would be the easiest way to get the wideband reading datalogged. Is there some setup like the one i had in my high school physics lab in which i could log realtime a/f results x rpm, with the a/f represented as voltage and/or a/f. how would i go bout setting it up. I know bout hondata and aem, but im on a mad budget and looking for the cheapest way possible. Is there some sort of datalogging program that i could download and a cable or two to get the info i want on my computer? remember cheap. thanks
This is a good wideband also:
https://honda-tech.com/zerothread?id=599740
it offers narrowband outputs, it offers a display already, and it has datalogging soon to come.
here is a diagram of how narrowband vs wideband outputs look:
http://plxdevices.com/M-200/Wi...h.jpg
http://plxdevices.com/M-200/Na...h.jpg
Looks like plxdevices is entering the fray with a controller for the BOSCH sensor. The new BOSCH (LSU4?) is a windfall to the tuning community because it is OEM equipment on some VWs and can be had in the sub $60 price range.
It is the PLX-devices.com m-300. I think I'll start a thread on some of the current offerings. Oh, btw here is a tutorial they offer on hooking up your wideband to an A/F meter: woot: http://plxdevices.com/PLXApp001.htm
-PHiZ
-PHiZ
i ♥ my honda
Global Mod
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joek84 »</TD></TR><TR><TD CLASS="quote">Im curious bout hooking up a wideband sensor to a js safeguard monitor. The sensor lets off a voltage right? like the aem? So how would it be possible to hook it up to the display for the safeguard? It would be pimptite to get accurate readings through the safeguards monitor.</TD></TR></TABLE>
I would leke to know more on this as well!
