b20 vtec timing issue?
Old Aug 28, 2010 | 03:46 PM
dc2_dustin!'s Avatar
Default b20 vtec timing issue?
just installed a b16 pr3-2 head on my b20b1 block and everything was installed correctly except i can't get it to turn over, im pretty sure i hit the timing tdc but it won't turn over, just cranks and is pushing air through the intake...any ideas??? thanks in advance
Old Aug 28, 2010 | 04:30 PM
Default Re: b20 vtec timing issue?
bump!
Old Aug 28, 2010 | 10:58 PM
mouab18c1's Avatar
First things first, check the simple ****.
Check for spark, fuel, and compression. Recheck timing and make sure the crank pulley is on TDC with both cam gears having the UP arrows both pointed straight up.
Old Aug 29, 2010 | 09:43 AM
yea just rechecked all the main things, timing is tdc, fuel pressure is 45, and good spark
Old Aug 29, 2010 | 09:46 AM
mouab18c1's Avatar
If everything is fine then check your grounds, firing order. Maybe try a different ecu.
Old Aug 29, 2010 | 10:18 AM
yeah it all looks good, and i tried other ecu's
wagonvanny
Apr 14, 2015 06:12 PM
gregwhart
Oct 7, 2007 07:48 AM
AE_Racer
24
Sep 13, 2007 02:53 PM
wpgcivic
Jan 16, 2005 06:15 PM
wpgcivic
Jun 17, 2004 06:18 AM
