CRX Timing Belt Change
Old Aug 27, 2010 | 07:38 PM
journeyquest's Avatar
Default CRX Timing Belt Change
90 CRX with only 88000 miles. Not sure if the belt has been changed so i plan on doing this soon. I bought the belt, tensioner and water pump. Is it normal to replace the cam and crank seals at this time? Do these have a reputation for leaking or is this just for extra measures?
Old Aug 27, 2010 | 09:18 PM
BiG ChOr!Zo's Avatar
Default Re: CRX Timing Belt Change
change them for extra measures
Old Aug 27, 2010 | 09:56 PM
TJChad's Avatar
I never did them with mine, it's all up to you and how **** you are about your vehicles. If it's not leaking i'd say leave it alone but if you're motivated then go for it!
Old Aug 30, 2010 | 08:06 PM
sleepercrxk24's Avatar
if there not leaking, and ur not a everyday mechanic id say leave it
Old Aug 30, 2010 | 08:18 PM
ef_cowboy's Avatar
just like grandpappy always said...if it aint broke dont fix it...but i know thats not always the case.i woulnt even worry.
Old Aug 30, 2010 | 08:40 PM
adamyee's Avatar
I didn't change mine and I have 180k on mine. No leaks.
Old Aug 30, 2010 | 09:15 PM
hatchet_honda's Avatar
that crank seal is a pain...cam is easy buut as stated. no leaks? no changy
Old Aug 31, 2010 | 03:21 AM
~sp33~'s Avatar
EFB055
There's a bit of trick to getting that crank seal to seat properly, the first time i put it on, the spring that holds the seal snug slipped off as i put it on, and it wasn't until i'd put EVERYTHING back together and started the car did i realise that it wasn't forming a proper seal. Needless to say, the car dropped its whole sump of oil on the driveway by the time i could turn the car back off lol.
Not saying you'll get it wrong, but if it's not broke, don't fix it
Old Aug 31, 2010 | 07:40 AM
wheelgarage's Avatar
That thing has low miles...
I've seen low mile B18's, under 100k, with leaky cam seals. But on the D's, I seen seals go around 200k. Sames with the crank seals also....
If it isnt leaking dont touch them, just look them over. You'll probably replace them the next timing belt change.
Anyway, if you have the right tools and instructions, those seals are easy to replace.
Old Aug 31, 2010 | 07:42 PM
Thanks. 90,000 is recommended?
Old Aug 31, 2010 | 07:56 PM
Ken99287's Avatar
i just did all my seals and it was extremely easy. cheap too. the total for my three seals(cam, rear main, oil pump) was about $12.
oil pump gasket ran me another $0.79
Old Sep 1, 2010 | 08:44 AM
Timing belt or seals?
Old Dec 5, 2011 | 02:13 PM
chrishovencamp's Avatar
My timing belt slipped on my d16a6 and it won't start any ideas??
Old Dec 5, 2011 | 02:18 PM
90civic-ZC's Avatar
Seriously dude??? Seriously?! Make you're own thread and people would be glad to help you
freddy chavez
Feb 16, 2013 11:27 AM
sobey
Nov 9, 2008 09:55 AM
davelarue
Jun 7, 2008 02:44 AM
JaiDieM
Sep 11, 2003 06:55 PM
turrismaldon
Oct 29, 2002 07:33 AM
