poorman type r ...which headgasket and timing belt?
this has prob been covered before but i searched a little bit and cant find anything
i have a B18C1 block
with a B16A head
do i use a b16 headgasket and a gsr timing belt?
i am currently trying to put on a b16 timing belt and it seems too tight to fit
with a B16A head
You use a gsr timing belt, always match the timing belt to what block you have. Gsr or b16 will work provided that your still 81mm aka stock bore. The part numbers from acura and honda are the same for both head gaskets.
ok so gsr timing belt
but civicgsrturbo32 im 81.5mm
had to bore the block .20 over
i got a regular b16 headgasket ..will this work ?
sasha_mitchell
Sep 7, 2008 03:39 PM
TheThiefTheKnife'NTheGun
Jan 25, 2005 09:40 PM
