new to honda modding want to build turbo crv
Old Aug 27, 2010 | 02:25 PM
40l sahara's Avatar
Default new to honda modding want to build turbo crv
Okay my real hobby is my jeep but my dd is a very well taken care of 2000 honda crv. For some weird reason I want to turbo it. I cant just leave it stock. It is a auto so not the best but for now im going to leave it stock. I will add a decent sized trans cooler. If it blows i will build it up. So as far as the motor it's a bone stock b20z. For the turbo I'm thinking a turbonetics t3/t4 would do the job well along with a cast manifold. For boost About 7 to 8 psi. As far as the piping goes i dont know if the piping and a ic for anouther honda can be made to fit or not. Under the hood the crv looks just like many other honda's. What i really need help on is what I would need for fuel managment. I would rather stay away from a fmu. I'm not a huge fan. It needs to stay obd2 as it needs to pass emissions. In ct if the check engien light is off it will pass. Will I need a better fuel pump? What size injectors and as far as the computer and map and stuff im not shure I've never boosted a honda.
Thanks for the help.
Old Aug 28, 2010 | 05:41 AM
spawn_616's Avatar
Default Re: new to honda modding want to build turbo crv
any stand alone will work aslong as u piggyback the oem ecu with it,thats how my eg is set up,u need a atleast a 12row cooler,rebuilding an auto is expensive-thers really no reason to keep it auto unless u have cash,want to be different/or handicapped,if ur not looking for big power why not use a smaller turbo,440cc and up will be sufficeint for injectors,and a walbro fuel pump to be on the safe side,get a rebuild kit for the trans if u plan on goin close to 200whp,my 15yr old trans lasted 6months on 236whp,urs mite last longer
Old Aug 28, 2010 | 07:19 AM
40l sahara's Avatar
ok?
Old Aug 28, 2010 | 07:24 AM
40l sahara's Avatar
I may convert to a 5spd if it blows but for now i will leave it as is. I had the trans out and while it was out i split the cases its in great shape. It does have 130k on it but i was amazed it was my moms car and is alot of highway miles. does anybody know if there are any threads on a crv 5spd swap?
Old Aug 28, 2010 | 08:51 AM
spawn_616's Avatar
i think its the same as egs or eks,just gta get the dash changed out and the one mount at the rear,u could follow the eg one in the 92-00 model section,and wen u get stuck just ask for help,or sell it and fit a K
mindless4banger
Engine Machining & Assembly
Jan 29, 2016 09:08 AM
wagonvanny
May 13, 2015 03:15 PM
1994alex
Jul 29, 2014 05:21 AM
oMek
Oct 17, 2003 01:21 PM
xxturbohondaxx
Oct 5, 2002 06:34 PM
