motor build questions
NOW im going to be straight up please can we stay on topic and if you dont know a for sure answer please dont wast my time. not trying to be an *** but want to get straight to the point.
now with that being said I have built a GSR b18c1 fully built less then 30 miles ago and im already throwing a rod bearing. NOT A PROBLEM im going to take it to a different shop and have it done right this time.
now my question is I am using right now stock type R cams in my build but was wondering if I can go with a way better cam and keep vtec or should i use a set of cams that kills vtec? i like how vtec kicks in so id prefer to keep vtec please keep this in mind. Im also going to turbo it this time around so i need some input on a decent turbo build. Im not going to say money is not a problem because im an average guy and far from rich so this is going to take me a few months to do so lets try to keep "price vs performance in a decent range for the money"
here is a list of what i have done to the motor now please let me know if I need to change anything what cams to go with and what turbo parts to go with. never mind the prices this is a copy and past of my blue print so far
SUSPENSION
SKUNK2 PRO SERIES FRONT CAMBER KIT controll arms $325
kyb adjustable struts $350 for the front plus $350 for the rear
TEIN S-Tech Springs $249.95 new
GSR rear disk break conversion $200
SPC Performance Cross Drilled and Slotted Vented Front Rotors $300
JDM front upper strut bar $50
SPC rear camber kit $80
new oem driver cv shaft $90
MOTOR
Edelbrock victor X intake manifold $585
78mm DH Racing throttle body $325 it is also port matched $150
Hondata im gasket, $60
PTE Precision Turbo Fuel Injectors 310cc $225
chipped p28 ecu
greedy extreme timing belt $160
Brand new JDM cap and rotors $75
Vision Motorworks 10.2mm Spiral Core 100% Pure Silicone Spark Plug Wire $75
Bosch Platinum Plus +2 Spark Plugs $22
T304 stainless steel with mandrel-bent. ( chrome polished ) racing header $150
T304 stainless steel with mandrel-bent. ( chrome polished ) full exhaust $150
new head gasket set $190
STR fuel rail with fuel pressure gauge $120
BLOCK
USDM B18c1 block $1400
Darton Sleeves $600
BLOX RACING BLOCK GUARD $100
sleeved block with block guard install $1800
Mahle 10.5 to 1 compression pistons $600
New Mahle rings diamond cut to fit $80
scat h beam rods & ARP rod bolts $500
scat crank $600
new water pump $100
new oil pump. $190
ACL Rod Bearing Set $70
ACL Main Bearing Set $110
HEAD
I just had the head port and polished bead blasted and completley rebuilt this cost me $1000
ARP head studs $150
Skunk2 Racing Tuner Series dual Valve Spring and Titanium Retainer $407.98
Skunk2 One-Piece Forged Valves - High Compression $ 321.19
type r cams "cams were just micro polished before being installed"
AEM adj cam gears $125
BLOX RACING CAM SHAFT SEAL $15
TRANSMISSION
B16 tranny none LSD $700
ACT Extreme stage 3 pressure plate and 6 puck sprung clutch $798
I will change the transmission to an LSD so no worries there.
my plans are to build a stupid fast drag car for car show purposes. this car will be my "drag car / show car / weekend car". its a 92 civic hatch which when I get done will be a jaw droper front mag cover type car so be on the look out and stay tuned.
im going to start on stripping the car tomorrow so i will open another thread with a start to finish on everything and with you all helping will play a big part in my build this is why i say at the top please lets stick to the point and not get carried away
thanks for the time and together with ideas lets build this car.
SUSPENSION
MOTOR
chipped p28 ecu
BLOCK
Darton Sleeves $600
scat crank $600
new water pump $100
new oil pump. $190
HEAD
ARP head studs $150
TRANSMISSION
mistaashby12
Sep 6, 2008 10:12 PM
