ECU PINOUT OBD2a automatic civic
Does anyone know where i can get a 96-98 civic (obd2a)automatic ecu pinout
diagram ?i have a obd1 chipped ecu and want to use it for a 97 civic (obd2a) automatic. I have a obd2a to obd1 jumper harness. i have it allconnected except for the d-plug which is for the automatic transmission.any help would be appreciated. -thanks
Here is a link, I used this to wire up my F/IC. Scroll down to PAGES 237-240...you will find what you are looking for.
http://powweb.hondahookup.com/manual...6-98_civic.pdf
OBD1 ECUs will not control OBD2 trannys. All OBD1 automatic transmissions had was 2 lockup solenoids. OBD2 has those plus a mainshaft speed sensor, countershaft speed sensor, linear solenoid and 2 shift solenoids.
i dont need it to control the tranny. Its stuck in 2nd gear, he races circle track.
i did leave it disconected and when i turn power to the key, you can hear that it does not give power to the fuel pump to prime it.
Any suggestions? I look at the pin for B which controls the tranny. There has to be something im missing for me to make this work.
