i have NO oil pressure in my si please help
Old Sep 17, 2002 | 05:09 PM
00BuMSi's Avatar
Default i have NO oil pressure in my si please help
i have checked both the sending unit and the switch and its killing me. i cant figure it out. i just rebuilt the head and put new valves, springs, retainers, alot of machine work, and new cams. Please HELP!!!
[Modified by 00BuMSi, 2:11 AM 9/18/2002]
Old Sep 17, 2002 | 05:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: i have NO oil pressure in my si please help (00BuMSi)
How do you know? At any rate I would check the cam seals and make sure everything in the head is trq. to spec. Next try the oil filter and drain plug. maybe you forgot?
My buddie had a chev 350 and a cam nut wasnt in far enough and it wasnt getting ne oil. Once it was tighted to spec he got oil pressure. Good luck
Blaze
Old Sep 17, 2002 | 05:27 PM
HybridFiend's Avatar
You said that you just did some head work, and then this problem accured so that is a good start to start double/tripple checking what you did in the head. On your intake/exhaust rocker shaft orifices you have o-rings, plus did you make sure they were clear, sometimes with time buildup will acure and clog them. In the center of the Head there is a dowel pin with a o-ring, your #3(center) camshaft holder bolts down onto it, if the o-ring is replaced with too thick of one it does not seal which can cause low oil pressure. The last thing I can think of is the dowel pins to the Block/head, if they are not perfectly clean,smooth, and easy to remove/insert they can cause the head not to seat/seal on the block properly, which in turn could give you a low pressure.
Old Sep 17, 2002 | 05:35 PM
00BuMSi's Avatar
Default Re: i have NO oil pressure in my si please help (HybridFiend)
i know about the o-rings and the dowels are in right. i checked all that and still cant figure it out
Old Sep 17, 2002 | 05:41 PM
How is your idle speed, does the light only come on at idle? Is your idle too low?
Old Sep 17, 2002 | 05:46 PM
00BuMSi's Avatar
my idle is at 500-650 rpms and no light what so ever comes on
Old Sep 17, 2002 | 05:55 PM
I have IMed you and you are not responding. You don't have a Low oil pressure MIL, so what is your oil pressure at idle (it should be 750rpm) and what is your oil pressure at 3000 rpm? Is this with a good accurate pressure gauge? Are you getting a CEL that has something to do with your Vtec not getting enough oil pressure? Tell me more what is going on, I want to help you out.
Old Sep 17, 2002 | 06:08 PM
I sent you more IM's with some possible solutions, you responded to my first IM's but now your not. So check your IM's iight.
Eddygee53
Apr 21, 2016 12:08 PM
EsotericImage
Oct 19, 2013 06:18 AM
sirwags
Jul 31, 2005 07:13 PM
y2kgixxer
Jan 23, 2002 10:05 AM
Civic TSI
Aug 20, 2001 08:17 AM
