Koni Yellow Interchangeability
Old Sep 17, 2002 | 05:05 PM
netnutshatch's Avatar
Default Koni Yellow Interchangeability
Ok, I have a set of Koni Yellows that came off my 99 EK, and I am planning on using them on a 92 CX w/ GC coilovers. My question is, will these bolt right up or will there be any problems? According to Koni's site, the part numbers for the front shocks on EG's and EK's are identical - 8041-1152, but the rear shock part numbers are different: 8041-1153 for the EG and 8041-1213 for the EK. Anyone have any input on this?
Old Sep 17, 2002 | 05:15 PM
nwdave's Avatar
Default Re: Koni Yellow Interchangeability (netnutshatch)
You will need different rear LCAs.
Old Sep 17, 2002 | 05:33 PM
Default Re: Koni Yellow Interchangeability (delsolguy)
Forgot to mention, I will be running GS-R rear LCAs...
Old Sep 17, 2002 | 06:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Konis for 92-95 Civics and 94-01 Integras are exactly the same all around. You will be fine.
[Modified by PatrickGSR94, 9:03 PM 9/17/2002]
Old Sep 17, 2002 | 06:41 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Maybe I'm wrong, as I don't own a 96+ Civic, but aren't their LCAs a different length than 92-95 Civics and 94-01 Integras?
Old Sep 17, 2002 | 06:45 PM
hXc-DC2's Avatar
Default Re: Koni Yellow Interchangeability (SkyeC)
I was just wondering the same thing. I just spent a buttload of money on my koni's and now im thinkin about buying a new car. im sure if you use the right parts they'll fit.
Old Sep 17, 2002 | 06:46 PM
hoya_10fintec's Avatar
Default Re: Koni Yellow Interchangeability (PatrickGSR94)
correct me if i'm wrong... i heard the front ones would fit on '92-'95 if u use '96-'00 front forks... don't know about the rear ones... but i don't think the rear shocks will fit... hope this helps...
Old Sep 17, 2002 | 06:57 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Koni Yellow Interchangeability (hoya_10fintec)
I'll set it straight:
I have EK Konis on my EG/EH hatch.
The front bolt directly up with nodifferences whatsoever, BUT the rears require modification to your Civic's or Integra lower control arms.
The EK-style struts has a thinner bottom fork, so you must get a grinder or a ziz-wheel and cut some thin slices off of the lower control arms bushings where the lower strut fork slides over it.
In my case I was using Energy Sus bushings, so I simply trimmed my bushings down on a bandsaw.
That should settle it.
Old Sep 17, 2002 | 07:20 PM
Community Builder
Suspension geometry (and thus LCA length) is the same across all 94-01 Integras and 92-00 Civics. It's just the LCA bushings.
Oops I got mixed, you have 99 Civic Koni shocks now, so yeah you'll have to trim the bushings in the GS-R LCA's to get them to fit.
Old Sep 17, 2002 | 08:10 PM
Well that's not too big of a deal. Now I know what to expect. Thanks for the input guys.
99Ek_Fred
14
Feb 22, 2017 03:32 AM
EM1fun
Suspension & Brakes
Mar 26, 2014 01:34 PM
Jonovision
Mar 30, 2008 07:14 PM
run-it-red
Sep 15, 2005 05:43 AM
need2buyaR
Feb 13, 2003 01:48 PM
