2000 Honda civic... Transmissions Issues!
I got a 00 Civic Swapped with a b series.
It has new master and slave cylinders, as well as a new steel braided line.
The tranny at times stays in gear, other times it wont go into gear.
If I pump the peddle a few times it eventually starts working again.
I've bled the clutch and bled the clutch and bled the clutch.. Same situation.
Is my clutch too stiff?
Its an ACT 6 Puck with the Xtreme pressure plate I believe..
Does life just hate me?
whats going onnnnnnnnnnnnnnnnnn?!
Sounds like you still have some air in there. I have a B16A2 swap.
I didn't check the fluid level for about a year, and it got a little on the low side.
I first noticed the low fluid level when I started missing shifts, here n' there -- once or twice a day. And, it felt like the clutch peddle was actuating a little closer to the floor.
I topped off the fluid and thought that would take care of it -- but it didn't.
I drove it that way for a few days (pumping the pedal occasionally) thinking the air bubbles would eventually work there way back to the reservoir. This went on for a week. I figured, if it was still doing it by the weekend, I would purge the system.
On the last day of the week, it magically started working again. I assume the air bubbles finally worked their way back to the reservoir.
Anyway...
What you are describing is (essentially) the same thing that was happening to me, when I had air in the system. The only difference is... I could still get my car in gear.
If it was me, I'd bleed the system again...
Anyway...
muddmonky
Transmission & Drivetrain
Apr 3, 2013 09:30 PM
stealth89hatch
16
Feb 18, 2005 10:53 PM
