b series wont start vid inside.
Old Aug 25, 2010 | 03:50 PM
visching101's Avatar
Default b series wont start vid inside.
Alright trying to help someone out. A friend just recently swapped a b16a2 into his EK hatch and cane seem to get it started.
I guess i should provide some info... Its a b16a2 with a gsr trans. chipped p28 with stepdown harness
new thermostat
new mishimoto colder fan switch
new bosch spark plugs
new rywire dizzy stepdown harness
new tranny mount from honda
new starter
new slave cylinder
Some things that have been ruled out... It get fuel and spark, timing is fine.
here is the vid... Hope someone can help.
VID00007-20100806-2125.mp4 video by jj1116 - Photobucket
Old Aug 25, 2010 | 04:01 PM
B20N2o's Avatar
Default Re: b series wont start vid inside.
Is it trying to start at all, like jumping and misfiring, if so maybe double check the injector plugs are in the right sequence, check you got ALL the grounds on also
Old Aug 25, 2010 | 04:11 PM
I dont know why the vid didnt post... it trys to start but just wont... vid below.
http://s1011.photobucket.com/albums/...00806-2125.mp4
Old Aug 25, 2010 | 04:12 PM
Green Crack's Avatar
Have you put in a little starting fluid in to see if it will at lease start up that way?
Old Aug 25, 2010 | 04:19 PM
hondawhiz's Avatar
bro the most common problem with this could be that the map and tps sensors are backwards, or that the fuel rail is different and was a side input fuel rail, so gasoline isnt going any further than the fuel line. trust.
Old Aug 25, 2010 | 04:20 PM
i will have to try those 2 things tomorrow... its really killin me lol.
Old Aug 25, 2010 | 04:52 PM
spoon_fed_civic's Avatar
sounds just like the b16a2 i put in my 99 a couple weeks back.
mine the dizzy was wired wrong and wasnt getting no spark.
check by taking a spark plug and hold it on the head and see if its getting spark.
Old Aug 25, 2010 | 06:18 PM
he told he had spark but ill double check tomorrow afternoon when i go there.
Old Aug 26, 2010 | 12:01 PM
did a compression test for him today and it was low across the board. 50-80 on all 4 cylinders.
Old Aug 26, 2010 | 12:46 PM
Former User's Avatar
Is the mechanical timing way off?
Are the cylinders flooded with fuel?
How did you do the compression test?
Old Aug 26, 2010 | 01:16 PM
he said he took the spark plugs out, put the tester in and tried to start the car allowing it to crank or turn over 5 times. I havent been able to look at the car yet so im just going off the info hes giving me. He said someone else looked at the timing and said it was good but when i asked him to send me a pic this is what he sent.
http://pictures.sprintpcs.com/mmps/I...itsize=615,500
Old Aug 27, 2010 | 03:22 PM
Ok so today we went and rented a compression tested again so we can do a wet test. The wet test seemd to go alot better, cyl 1-2 got 130-150, but cyl 3-4 got 90. He said the car also sounded like it wanted to start this time when he attempted to start it. I should have a new vid soon.
http://s709.photobucket.com/albums/w...rent=civic.mp4
Old Aug 27, 2010 | 05:53 PM
honda fossil's Avatar
check the valve lash if the valve are to tight they can stay open and or change the profile of the cam adjust valves and redo compression test.
Old Aug 27, 2010 | 06:00 PM
and if you do have the map sensor backward you can see it on the data list during cranking and or with key on engine off and step on pedal and see if the voltage changes
Old Aug 27, 2010 | 06:26 PM
b16a95eg's Avatar
If you guys took the distributor off, it could be that its 180* out of phase, you'd still get spark, but it would be firing at the wrong time
Old Aug 27, 2010 | 07:26 PM
hondawhiz's Avatar
make sure the spark plugs are in the right order!!!!!
sLoWrAcEr
Jan 16, 2010 08:38 PM
chinese buffet
Jul 16, 2006 05:09 AM
Rukusmasta2
64
Mar 19, 2006 07:46 PM
kasso
Feb 26, 2006 05:09 PM
neogenesis2004
May 12, 2004 02:27 PM
