Check engine light codes- need help
I have a problem with the engine light, I tried disconnect the battery, the fuse out to reset file and not any effect
I then switched to read that cable failure and showed a slowly following error 2krat 4krat beat and fast, that is an error 24 but this error is not written in Manuel
What could be wrong, or what to do to address the problem???
car is honda civic 1.6 esi
I have a light engine problem, an error is 1 probe and 14 engine idling, rotate both but I error repeats again, I turned off the battery and still shows an error
what else can we do? how to measure the voltage at the installation? to see where the problem is and how to best save problem
please help
please help
Code 1 and code 14, right? Those are indicating problem in the O2 sensor and IACV circuits.
Are you having idle and/or driveability problems? If so, clearly describe them.
at idle is not on some problems that the car would not function normally (do not jump up off plants that I do not know ms noticeable), otherwise I tried to disconnect the probe and iacv motorcek idle but there was no difference in operation
I zamenal motorcek and probe it with another and still the same
it is possible that what is on how the installation should give ohms or volts out the two exits to izmerilz multimeter, maybe who knows?
I replaced the sensor and the engine idling, reset the ECU (disconnected the battery and fuse clock out) vrjetno be able to reset the computer
but we throw yourself the same mistake again (I gave up a working probe)
where I was now the problem please help, does anyone know here to help or has experience with similar problems
Please Help
Please Help
ffspiel
Engine Management and Tuning
Apr 6, 2009 09:06 AM
