2000 b16 swap into a 97 si
Old 10-27-2010, 07:50 AM
civic46's Avatar
Default 2000 b16 swap into a 97 si
hey guys i can get a really good deal on a b16 swap that come out of a 2000 sir that has been rear ended....i wanna but it into my 97 si coupe....question is what all do i need?....i kno i need dizzy and motor tranny axels and linkages.....but can i use my wiring harness and comp out of my 97 si?
thanks for the info everyone!
Old 10-27-2010, 08:05 AM
Seagull Management
94EG8's Avatar
Default Re: 2000 b16 swap into a 97 si
You can use your wiring harness (you'll have to actually) but you'll need the B16 ECU along with an OBD2A to OBD2B conversion harness. You'll also need the mounts and rear engine bracket/T-bracket along with the stuff you already mentioned.
Old 10-27-2010, 08:15 AM
civic46's Avatar
ok and everythingt will plug in no problem? i wont have to add wires or sensors or extend wires?
Old 10-27-2010, 08:16 AM
Seagull Management
94EG8's Avatar
You may have to extend a couple of wires here and there but you wont have to add anything.
Old 10-27-2010, 08:17 AM
silverbullet9626's Avatar
how do u have a 97 si when the si only came out in 99-00?
Old 10-27-2010, 08:21 AM
civic46's Avatar
si in canada...the 99-00 in canada came sir(b16) and si(d16y8)
Old 10-27-2010, 08:22 AM
civic46's Avatar
thanks for the help 94eg8!!
mark78214
02-23-2009 05:57 AM
94excoupeSA
03-07-2006 09:40 PM
skeeterDX
11-03-2004 11:12 AM
boostin4door
07-24-2004 08:46 AM
Ehron
12-03-2002 03:27 AM
Quick Reply: 2000 b16 swap into a 97 si
