Car sometimes won't start...please help..
Old Aug 24, 2010 | 08:20 PM
91EF_Si's Avatar
Default Car sometimes won't start...please help..
Ok so I just got this car. 94 ls. Sometimes it will start just fine but other times it will just click. But if you jump the starter to the battery, it starts up right away. Tried 2 new starters and new battery. Any ideas?
Also the clutch doesn't have to be pressed in to start the car. It's always been 5spd, not converted.
Old Aug 24, 2010 | 08:24 PM
D16SiHatch's Avatar
Default Re: Car sometimes won't start...please help..
might be a failing ignition switch
if it starts without pressing the clutch then most likely someone bypassed the clutch interlock switch. look up where the switch is and see if anything looks out of the ordinary. all one would have to do to bypass the switch is permanently jump the 2 wires going to the switch to eachother.
Old Aug 24, 2010 | 08:37 PM
91EF_Si's Avatar
so would jumping the clutc switch cause this problem? thanks.
Old Aug 25, 2010 | 12:35 PM
91EF_Si's Avatar
bumppp
MayDayTegGS
Aug 26, 2012 08:30 PM
zerovandez
Apr 1, 2011 01:05 PM
dvgleyzer
Audio / Security / Video
Aug 29, 2010 08:57 PM
wood
Aug 16, 2005 07:09 PM
