HX RIMS: Which tires are best? 185/55/14?????
I've got some 185/55/14 tires that I'd like to keep...will they fit on the 14x5.5" HX rims? I've heard people sporting 185/60+65/14. Does either make your car appear lower?
Thank you!
Thank you!
Could anyone give me more insight? I did a quick calculation on tire sizes, and the diameter difference is at 6.2%....which is pretty high. Would switching from a larger tire to a smaller one do much damage-or is this really dangerous?
Thanks!
Thanks!
heres a useful link
6.2% is alot, will throw off your speedo ect.
http://www.1010tires.com/TireSizeCal...mp;vehicle=yes
the higher sidewall will fill in the wheelgap a bit more so I guess it would "appear" to be lower, but it would actually be higher up than your other tires.
6.2% is alot, will throw off your speedo ect. http://www.1010tires.com/TireSizeCal...mp;vehicle=yes
If you have EX/Si front brakes you would need to run 5mm spacers for it to clear the caliper bracket or you can shave off the brackets.
RIOredKIRKLANDcrx
20
Apr 28, 2004 09:42 PM
GenXcopz
14
Jan 14, 2004 05:00 PM
