Wont rev above 3000????
Old Aug 24, 2010 | 04:51 PM
45js45's Avatar
Default Wont rev above 3000????
1996 accord 2.2 non vtec...just replaced belt and rebuilt the head....the motor will start.....but idles very rough and wont rev above approx 3000 rpms.Ant ideas?
Old Aug 24, 2010 | 09:00 PM
nick455's Avatar
Default Re: Wont rev above 3000????
Just check if there is any problem with the modes you have done.Did same thing happen earlier?
Old Aug 26, 2010 | 06:39 PM
gianinline's Avatar
The car may be on limp mode. Any "check engine light" at all?
Old Aug 29, 2010 | 07:48 PM
F20B_accord's Avatar
did u get it tuned for this new mods? maybe bad a/f ratio
oh wait my bad lol i read it wrong u just rebuilt it with stock parts right?
Old Aug 30, 2010 | 03:16 PM
Jdmtmr15's Avatar
Since you just rebuilt the head then you had to disconnect the battery and the ECU is having to relearn everything. You are probably justy gonna have to go thru a drive cycle and then your car should be ok.
Old Sep 1, 2010 | 08:14 PM
lilned's Avatar
I had a problem with my car, but it couldnt rev above 2.500. I had a loose wire to the crankshaft position sensor. Check that might be it.
Old Sep 2, 2010 | 01:26 AM
HondaPartsHero's Avatar
Technical Hero
First if you have any CEL take care of that. Recheck cam timing.
Old Sep 2, 2010 | 03:16 AM
tommygun89hb's Avatar
+1 to this sounds like the Timing belt is off
JeromeyS
Feb 28, 2012 10:27 PM
cavrdave
Sep 5, 2011 07:40 PM
UGOT8UP2
23
Feb 18, 2009 07:53 PM
1sikhatch
Dec 26, 2005 10:09 AM
BadbluSi
15
Oct 24, 2005 09:44 AM
