Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
P0341
Old 02-28-2012, 03:16 PM
JeromeyS's Avatar
Default P0341
Well, I just replaced an exhaust camshaft on a '04 Accord, 2.4L and now I have P0341 showing up. It idles fine but won't get above 5000 rpm. I triple checked the timing before it went together and have torn it apart again and checked it once more, it is all good. I have read that it can come from stretched timing chains, tensioner, and the VTC actuator. I am leaning towards possibly the VTC actuator. Is there any way to check this? It ran fine before it was torn apart. I checked the tensioner again and the chain is tight and is out the same as it was before. Any advise is very welcome.
Old 02-28-2012, 03:54 PM
lazlong's Avatar
Default Re: P0341
Have you actually checked the cam sensor and connections?
Old 02-28-2012, 04:22 PM
My Name is Nobody
MSchu's Avatar
Default Re: P0341
stretched chains...
highly unlikely unless you really did a number to the motor prior to the initial tear down.
Old 02-28-2012, 06:58 PM
JeromeyS's Avatar
Default Re: P0341
I checked the connections and the sensors. Is there a resistance to check on the sensors?
Old 02-28-2012, 06:59 PM
JeromeyS's Avatar
Default Re: P0341
Originally Posted by MSchu
stretched chains...
Agreed, they would have given me a CEL prior to disassembly. It only has 60,000 miles.
Old 02-28-2012, 08:10 PM
D-JET's Avatar
Default Re: P0341
http://www.obd-codes.com/p0341
Old 02-28-2012, 10:27 PM
90sedan's Avatar
Default Re: P0341
Originally Posted by D-JET
That's generic information and doesn't really include anything that applies to this situation.
Op, here's what i would do. p0341 will only be caused by one of the following on this vehicle, incorrect timing, stretched chain, clogged or stuck open/closed vtc control solenoid, damaged camshaft lock pin, faulty vtc actuator or damaged cmp pulse plate. Since there weren't any issues before replacing the exhaust cam, i would look towards a vtc actuator or pulse plate issue, assuming the timing is correct.
Inspect the pulse plate on the exhaust cam for any damage (it's on the opposite end from the cam gear).
Did you remove the actuator from the intake camshaft? If so, was the actuator in the unlocked position when reinstalled? You may have damaged the camshaft pin if you used a impact gun to tighten the actuator.
If the lower cover is off then measure the tensioner rod length to check for a stretched chain. You want to measure between the tensioner body and bottom of the flat surface section on the tensioner rod. If the length is over 13.5mm then the chain and tensioner need replacement.
Next check the vtc oil control solenoid for any debris that may have clogged the screen. It's possible that the solenoid is stuck open or closed but likely would have been an issue prior to repair.
dj-t
04-16-2015 11:13 PM
45js45
09-02-2010 03:16 AM
zebstar1
Classic Hondas
01-26-2010 07:48 AM
Civicta
07-21-2008 06:30 PM
mo_thug_85
07-19-2008 12:28 PM
Quick Reply: P0341
