help with flywheel?? engine swap
Old Aug 24, 2010 | 04:39 PM
andera's Avatar
Default help with flywheel?? engine swap
I have a 98 accord DX Manual and I'm swapping in an f23a1 which had an automatic transmission. I just removed the flywheel from the DX and went to put it on the new engine but their's like a dowel on the crank which isnt allowing me to put the flywheel on. anyone know what the solution is?
Old Aug 25, 2010 | 03:22 PM
92civlude's Avatar
Default Re: help with flywheel?? engine swap
Just pull it out with some vise-grips.
Old Aug 25, 2010 | 04:40 PM
phootbag's Avatar
Bang it in with your forehead.
Old Aug 25, 2010 | 05:24 PM
SIRCB7 coupe's Avatar
My F22 has a dowel pin in it so i would say find a flywheel from a same year car or better yet you should upgrade your flywheel and clutch while you have it all apart. I got my fordged flywheel and heavyduty pressure plate and copper ceramic clutch disc for about three hundy on E-bay from gripforce clutches.
Old Aug 25, 2010 | 05:27 PM
hondawhiz's Avatar
whenever i do h22 swaps they have dowels and i grind them off when i cant take them off with pliers.
Old Aug 25, 2010 | 08:02 PM
tomw0's Avatar
Boy, some people... don't know the difference between a crankshaft and a flywheel. Grinding is one method, and vice grips work too, and if you are really good you can weld on something to be able to use a puller, as noted in another post. If you take the engine apart, you can whang on it from the back side using a hammer and chisel.
Best.
tom
immalooser
Oct 18, 2005 08:08 PM
b16a27
Nov 5, 2004 04:43 PM
m3dia_lab
Sep 28, 2004 03:02 PM
Rocks
Aug 23, 2004 12:27 PM
del_parker
Dec 30, 2003 10:30 PM
