Honda S2000 Honda S2000
what yr ecu + cluster doo i have >??
Old Aug 24, 2010 | 08:53 AM
geoscranny84's Avatar
Default what yr ecu + cluster doo i have >??
i have a s2000 ecu... it says 37820-PZX-a02
on it... what yr is that from >?
also have a s2000 cluster... > revs to 8gs, has to plugs in the back of it > how can i find out the exact yr it came from >?
Old Aug 24, 2010 | 09:44 AM
Default Re: what yr ecu + cluster doo i have >??
6 people look > no answer >?
Old Aug 24, 2010 | 09:56 AM
CRX Si69's Avatar
there should be part numbers on them some were, match those numbers online and im sure you'll find what year it is out of.
Old Aug 24, 2010 | 10:08 AM
JUSTINTHECOASTI's Avatar
CRX si69 is right...also if it revs to 8k more than likely its from an AP2(04 up)....
Old Aug 24, 2010 | 10:21 AM
TheMuffinMan's Avatar
He knows where you live!
Originally Posted by geoscranny84
i have a s2000 ecu... it says PZX on it... what yr is that from >?
Narrow it down by looking at the temp/fuel gauges
If you can't figure out it's not an 00-03 I don't know what to tell you.
Old Aug 24, 2010 | 10:58 AM
OK... ecu has to be 04+.
whats the diff 00-03 to 04+ ecu... i know 00-03 revs to 9k and 04+ revs to 8k...
Is there anything else Different ??
Old Aug 24, 2010 | 11:08 AM
camoy's Avatar
There are also the 06+ to think about those ECUs run the S2000 which are drive by wire.
Old Aug 24, 2010 | 05:04 PM
00-05 drive by cable 06 and greater are DriveByWire, 00-02 ECU run richer than the 03(runs lean)...00-03 ecu's redline is at 8.8 or 8.9k with fuel cut at 9.2k, 04 ecu's redine at 7.9 or 8k fuel cut at 8.2k
Old Aug 24, 2010 | 09:04 PM
thanks,......
Old Aug 25, 2010 | 12:32 PM
I think you'd get a better answer if you said what youre trying to do instead of asking dead end questions...
Old Sep 1, 2010 | 06:30 AM
Sooo is this a 04 ecu > 37820-PZX-a02
Old Sep 1, 2010 | 09:32 AM
JesusGLS's Avatar
NOP....if its 37820-PCX-A02 its from a 02-03 S2000......so yea your ecu is from a 02-03 S2000 since thats what my 02 s2k has..... and bout the cluster... im not really sure but sure its from a 04+ s2k since 00-03 rev up to 9k rpms....
Old Sep 1, 2010 | 12:11 PM
you would be out of luck if you have an 00-03 ecu with 06-up cluster...mainly because of drive by wire
ribal_gh
Honda S2000
Sep 18, 2013 01:47 AM
f20cmx5
Honda S2000
Sep 19, 2011 04:44 AM
aggreSHun
May 30, 2009 06:35 AM
veut
Honda S2000
Feb 26, 2006 08:27 AM
Black_eh2
Honda S2000
Apr 14, 2003 04:29 AM
