PLEASE HELP! tach swap prob need to be solved today!
So i did an auto to manual swap in my 2000 civic ex, and with the swap i put in a 98 manual ecu. Now, it is my understanding that the 98 ecu does not emit a tachometer signal, and the manual derives its signal straight from the distrubutor. Thus, i bought a manual 97 integra cluster because no matter how hard i tried to wire the dizzy up to the auto (with tach) cluster in my ex, the signal just wouldn't work (i believe the frequency was too different). So, i used the wiring diagram provided by BlueIntegraBoy on this website and i basically got everything to work besides 3 problems... 1. My tach still doesnt work. 2. The gauges don't light up at night with the headlights. and 3. Not only did i have an extra yellow wire that shouldnt exist according to the diagram, but also my turn signals dont work if i have the low fuel light wire in, but also if i dont have that wire in, my high beam light doesnt work
anybody have any idea what i should do? ive been trying to troubleshoot and plug certain wires in different places but i still havent gotten everything to work
also, ive theorized that that yellow wire has somehting to do with the automatic, but im not sure what, and i havent been able to pin down its purpose through the haynes manual (no pun intended). any suggestions? also, if possible, im only home for a day from college so id like to fix this before i drive in the early morning tomorrow...
u miht have to plug the blue wire from dizzy to ecu to make tach work. but idk which plug it is.. this is where im stuck too...
soccermike
Aug 16, 2010 08:06 AM
TKL
May 15, 2003 08:36 PM
