Help From Lincoln 275 Tig Owners.
Old Aug 23, 2010 | 11:53 AM
BEfab's Avatar
Default Help From Lincoln 275 Tig Owners.
Alright so I hate to show my ignorance. However, I have searched all over the internet looking for the answer. I have also changed a million settings on my machine and have not figured it out.
Is the Lincoln 275 capable of doing dc welding without having to scratch start??? If so what settings do I need to change.
Old Aug 23, 2010 | 01:39 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Help From Lincoln 275 Tig Owners.
I am assuming you mean Precision Tig 275?
I have one, and I was unaware that you COULD scratch start with it. I thought the only way was with the foot pedal or a hand controlled switch.
You can scratch start with a line running off a stick lead but how do you do that on the regular tig setting?
Old Aug 24, 2010 | 04:44 AM
dubzackvr6's Avatar
not to sound like a moron, but is the machine set to TIG instead of STICK?
Old Aug 24, 2010 | 09:46 AM
BEfab's Avatar
no it is diffidently in tig mode, with a foot pedal, but I am referring to having to touch the metal for the arc to start.
Old Aug 24, 2010 | 09:51 AM
E-Rok's Avatar
EPIC TUNING
you shouldnt have to do that.
Old Aug 24, 2010 | 10:21 AM
BEfab's Avatar
which is why i feel like i either have a setting wrong or there is a problem with the machine itself. The machine is approx. 2.5yrs old. To be honest, I cannot remember if it has always been like this, it just started really bugging me recently.
Old Aug 24, 2010 | 01:28 PM
E-Rok's Avatar
EPIC TUNING
there is no scratch start setting on a PT275. either some sort of ground issue or a problem with your machine. I have never had such an issue with mine, its about the same age.
Old Aug 24, 2010 | 04:41 PM
JDMCRX's Avatar
I have a PT 185. Its not a scratch start. You use the pedal to start the arc. Just full throtle the peddle real quick then back off.
Old Aug 24, 2010 | 05:07 PM
E-Rok's Avatar
EPIC TUNING
why would you have to full throttle the petal to establish an arc? it should be making an arc from like 5amps.
Old Aug 24, 2010 | 07:07 PM
Sobe_Death's Avatar
Have you checked the High Frequency spark gap? It might need to be cleaned and regapped.
Old Aug 24, 2010 | 08:18 PM
E-Rok's Avatar
EPIC TUNING
good point
Old Aug 25, 2010 | 04:00 PM
JDMCRX's Avatar
Im just saying my PT185 starts a arc at 5amps no problems. Like stated check your High FQ spark gap
Old Aug 25, 2010 | 09:23 PM
KFMRC's Avatar
There is also a 2 step/ 4step switch for start control /crater fill This should be set on 2 step for foot pedal use. 4 step is for the remote momentary switch on the torch handle. This is a really nice feature of the machine.
2-STEP/4-STEP TIG/STICK mode control switch. 4-
STEP mode requires the use of an optional Arc Start
Switch. This welding mode reduces fatigue by eliminating
the need to manually control the weld current
during the weld.
• Down Slope Time control is active in 4-STEP TIG
mode. It controls the amount of time (approximately
1 to 10 seconds) it takes the weld current to ramp
down from the Preset level to 25% ±10% of that level.
• Post Flow Time control is active in the 2 and 4-STEP
TIG modes. It controls the amount of time (approximately
5 to 50 seconds) the shielding gas flows after
the weld is completed
Built in High Frequency Generator automatically performs
in the correct mode. If the machine is in STICK
mode, the HF stays ‘OFF’. IF the machine is in DC
TIG mode, the HF comes ‘ON’ and stays on until the
arc is established. IF the machine is in AC TIG mode,
the HF comes ‘ON’ and stays on continuously to stabilize
the arc.
If you need the manual go to lincoln electric and you can download it.
Old Aug 25, 2010 | 09:47 PM
E-Rok's Avatar
EPIC TUNING
Is that only on newer models or what? I think mine is an 06 model.
Old Aug 26, 2010 | 08:00 PM
AutoSelectTuning's Avatar
Had the same thing happen to me a couple of times. It was a grounding issue.
Old Aug 28, 2010 | 10:08 AM
fbcfab's Avatar
i had same problem it was high freq gap
Old Aug 30, 2010 | 08:41 AM
BEfab's Avatar
nevermind just found it in the owners manual
Old Aug 30, 2010 | 09:02 AM
BEfab's Avatar
ok so I adjusted it. It measured .018, I adjusted it to .015 like the manual suggested. The problem still seems to exist. I am probably going to call Lincoln and see if they can help me.
thecivicsi
May 8, 2012 07:26 PM
killaj12
Jul 6, 2005 02:18 PM
_Endless_
Jun 16, 2003 09:12 AM
awall
May 16, 2002 10:37 AM
