Shooting for 500whp
Going to get tuned again tomorrow the car currently makes 420 whp on about 20 lbs on e 85 will upload pictures and dyno graph soon setup consists of:
Ge 84.5 mm b18c
Wiseco pistons
Eagle rods
Gsr head w type r cams
Buddy club valvetrain
Fullblown dual fuel pump
1200cc precision injectors
Precision 62/62 bb turbo
Neukin ramhorn
Precision 650hp ic
It's ran on hondata s 300
I'm hoping to make 500 or more I believe my fuel set up is good to 600 or so wish me luck!
Ge 84.5 mm b18c
Wiseco pistons
Eagle rods
Neukin ramhorn
Precision 650hp ic
My bad It's a golden eagle sleeved block the car was tuned conservatively when it was tuned and had gsr cams idk how much more the type r's will do but went that route over the skunk 2 pro 1s because my goal is to make 500 and still be a daily
Sooooooo. Tuned today had some scary sh*t happen the strap on the dyno was to tight and ate up my tire shot a zip tie from somewhere hit my buddy in the head stopped just in time before the tire gave out ended up making 530whp and 390trq on 26 lbs still somewhat of a conservative tune tuner said could make more and the injectors are only at 80 percent but it was a long day and decided to stop will post up dyno vid tomorrow
uh...your dyno run made almost the same numbers as me, 7 hp higher lol a little more tq...good job - also id recomend BC cams...when i put them in it made a hell of a difference and sounds better aswell.
bc cams? blox? or ive never heard of them? whats your setup?
next is id 2000s and hopefully 600 my injectors were being weird but called precision and there injectors are not e85 compatible so they say
slowsleeper
28
Oct 16, 2008 10:31 AM
zhan28
11
May 17, 2007 12:55 PM
