civic starts then cuts off
Old Aug 22, 2010 | 04:10 PM
dvgleyzer's Avatar
Default civic starts then cuts off
hey guys, so i parket my car the other day and got back into it 15 min later and it started but cut of a second later. Didnt matter if i hit the gas, it would still bog and cut off. That day i ran on e and filled up so i thought it was the fuel filter. I changed it the next day and it did the same thing. later on i noticed if i keep the clutch pedal in and keep the key turned all the way, the car stays on... but if i let go of either, it cuts off. I also tried a different ignition harness, but that time it would just crank and not even turn over. Im starting collage tomoro and i got work so please help me out guys!! thanks in advance. o also it looks liek the clutch ignition switch is a little wet, but if that goes bad i believethe car wouldnt even crank...
Old Aug 22, 2010 | 04:16 PM
dvgleyzer's Avatar
Default Re: civic starts then cuts off
o btw its a 95 ex coupe.. .
Old Aug 22, 2010 | 04:27 PM
dvgleyzer's Avatar
o the cars a 95 ex coupe btw. w/ obd1
Old Aug 22, 2010 | 05:01 PM
Former User's Avatar
Any CEL codes?
Running the tank completely out of gas can destroy the fuel pump, so you may want to measure the fuel pressure.
Old Aug 22, 2010 | 05:38 PM
dvgleyzer's Avatar
Originally Posted by RonJ@HT
Any CEL codes?
i tried to check cel, and it just blinks once....waits like 3 seconds, blinks again, waits like 3 seconds blinks again.....and so on.
Old Aug 22, 2010 | 05:43 PM
Green Crack's Avatar
Is it a quick blink or a long blink.
Old Aug 22, 2010 | 05:46 PM
dvgleyzer's Avatar
long
Old Aug 22, 2010 | 05:50 PM
That's intake air temperature sensor and may cause bogging. Try taking it off and cleaning it, if the code doesn't go off buy a new one.
Old Aug 22, 2010 | 05:56 PM
dvgleyzer's Avatar
o ok. could it cause the car to turn off like that? or will that just solve the bogging
Old Aug 22, 2010 | 06:03 PM
Go_Race_Your_Self's Avatar
Two Piece
Check for vacuum leaks too.....
Old Aug 22, 2010 | 06:27 PM
dvgleyzer's Avatar
i will tomoro asap. also i notices smoke come out of the air filter, so i took the intake off and saw it was coming from the butterfly opening when i opened it....this was after a changed the fuel filter.it only did it once, and didnt change anything in any way...
Old Aug 23, 2010 | 09:48 AM
dvgleyzer's Avatar
ok so i checked my fuel pump, and its not making that like 2 second noise when i put the car in run...i checked if it had spark and its there. theres fuel pressure on the fuel filter...and going into the injectors...could injectors be bad? i noticed before the car wouldnt start, when it did it was kind of hesitant
Old Aug 23, 2010 | 10:03 AM
That's code 1 for the O2 sensor circuit.
If the fuel pump does not prime, then you would have no fuel pressure. If the fuel pump does not run but has battery voltage and good ground, then it is toast.
Old Aug 23, 2010 | 11:05 AM
When i asked him if it was a quick flash or long flash he said it was long, so wouldn't that be 10?
Old Aug 23, 2010 | 11:07 AM
You are correct sir. My mistake.
Old Aug 23, 2010 | 11:32 AM
dvgleyzer's Avatar
well it doesnt make that noise, but the fuel filter has pressure for a second and then looses it. could it have anything to do w/ my map sensor, fuel relay, main relay, whatever?
Old Aug 23, 2010 | 11:37 AM
Remove the fuel fill cap and put your ear to the hole while a buddy turns the key from off to ON(II). Do you hear any low humming noise for 2 seconds?
Old Aug 23, 2010 | 01:57 PM
dvgleyzer's Avatar
i took the backseat out and i looked at the 2 connectors and they r SUPERRRR dirty inside.and i can somewhat hear teh flow going through the fuel pump. sounds a bit rough though, like not a perfect stream. stil cant hear it eengage when i put car in run position
Old Aug 23, 2010 | 01:59 PM
If the fuel pump connector has battery voltage on the power wire and good ground on the black ground wire, then the fuel pump is toast.
Old Aug 23, 2010 | 02:21 PM
dvgleyzer's Avatar
but would it make it so that it would turn on and then shut right off?if the pump was done wouldnt it just not start at all?just crank?also, i tried a difirent ignition switch and all it did for taht one was just crank , not even turn over. itll turn over w/ the original one i had
Old Aug 23, 2010 | 02:29 PM
Your ignition switch is fine because you have spark at the plugs. Again, you likely fried the fuel pump by letting the tank run empty. There's all kinds of almost dead. Your fuel pump is almost dead not completely dead. But for all intents and purposes, it's dead. You can verify that it's almost dead by doing the voltage and ground tests on the fuel pump connector as I have already mentioned. If you are not willing to do some electrical testing, then you are left to guess and replace parts at random ($$$). It's your choice.
Old Aug 23, 2010 | 02:54 PM
dvgleyzer's Avatar
ok i really appriciate it man. ima get on that asap. its kinda hard w/ school and work lol
Old Aug 23, 2010 | 04:50 PM
dvgleyzer's Avatar
just ordered main relay. should be in in a few days. we'll c where that takes us. i just realized that it only clicks 2 times when im starting teh car too....maybe it IS the main relay
Old Aug 24, 2010 | 08:59 AM
dvgleyzer's Avatar
IT WAS THE MAIN RELAY!!THANKS A LOT GUYS!!
sibbs
Honda Civic (2001 - 2005)
Aug 2, 2015 07:42 AM
wyte_myke
39
Jul 18, 2014 05:21 PM
seaninfla
Jan 22, 2010 07:53 AM
nonpareil
Dec 25, 2009 06:29 PM
Got Snail 2
15
Nov 20, 2007 04:21 AM
