Buddy Club Cam GearTiming.. Help Please.. Pic Here
Old Aug 22, 2010 | 11:42 AM
CRXherbie91's Avatar
Default Buddy Club Cam GearTiming.. Help Please.. Pic Here
I no longer have my stock cam gears, and it has been over a year or 2 since i did the timing with these cam gears.. they are buddy club cam gears... in the picture im showing do i have it right?.. Should i use the White Lines on the cam gears instead of the Degrees? ... Basically What Should Be Used as the UP Position, The Degrees (which there are 2) or the white marks (Which are 3) .. or do i have it correct? ..
Just incase you cant tell in the picture, i have the UP position with the degree markings, and i have the other degree markings meeting in the middle, it seems to make sense, but i could possibly be wrong, but i dont want to make a easy mistake on expensive motor, any info is appreciated, thank you.
Old Aug 22, 2010 | 05:24 PM
Default Re: Buddy Club Cam GearTiming.. Help Please.. Pic Here
nobody has or knows how to set cam gear timing.. i did some more research but still came up empty handed for a solid answer, except, i did come across a website im going to post the link, and click on the 3rd picture of the engine on an engine stand, it shows the cam gears on the motor, but my question is, are those at TDC? it makes sense to be.. i dont know if it means anything but buddy club is also stamped on the cam gear at the bottom so you can read it, if someone can get back to me i would appreciate it, i think my way is wrong, but someone on a different forum said its right, but i really think the way in this link is correct.. can someone possibly clear this up so i can finish my build with confidence? thank you
http://www.risingsunperformance.nl/b...r-b16-18.html#
its the 3rd picture.
Old Aug 22, 2010 | 08:30 PM
bakomack's Avatar
on your 3 white lines. youll notice 2 of them are across from each other while one is inbetween the 2.
use the middle line to point up and the other 2 white lines will be level with the head.
LaosGuySi
Jun 29, 2007 12:16 PM
machine4321
Mar 29, 2005 03:44 PM
cadougherty_67
Mar 6, 2005 06:11 AM
Brewer
Feb 2, 2005 10:48 AM
