ITR front sway bar On 1994 EG cx questions
Old Aug 21, 2010 | 05:34 PM
EusebioSam19's Avatar
Default ITR front sway bar On 1994 EG cx questions
so i picked up a front sway bar for my eg, it also came with the lower control
arms seeing that i have a cx and would not be able to run a sway bar with my stock lca's
although i dont see where the mounts from the swaybar bolt onto, is their a thread somewhere explaining the install, im basically just lost on where to mount the swaybar from its d links and how the endlinks bolt up to the lca....
Old Aug 21, 2010 | 11:21 PM
Default Re: ITR front sway bar On 1994 EG cx questions
help
Old Aug 21, 2010 | 11:36 PM
98civdx's Avatar
Master Detailer
Take a look at the back of the lca, where the complance bushing is. Where it mounts to the car will 2 little holes on each side, that is where the d bracket bolts to. Sometimes they can be kind of difficult to see, but they are there.
Old Aug 22, 2010 | 07:21 AM
kaiba's Avatar
Remove your stock lower control arm. Use everything you have from the R.
Old Aug 22, 2010 | 07:25 AM
another thing do i have to drop my exhaust and shift linkage?
Old Aug 22, 2010 | 09:20 AM
94EG8's Avatar
Seagull Management
Theres actually 1 stud thats part of the subframe/crossmember and 1 threaded hole for a bolt, at least as far as the '92 - '95s are concerned
Yes you do, I just put a factory sway bar on my '94 sedan last weekend, it just wont fit without dropping the exhaust and shift linkage.
Old Aug 22, 2010 | 09:24 AM
Kidnkorner's Avatar
What sway bar do you have to put in the back? Putting a big, beefy sway bar up front with nothing in back is going to create some serious understeer.
Old Aug 22, 2010 | 11:24 AM
98civdx's Avatar
Master Detailer
94EG8, I did not know that, thank you for adding that.
When i put my front sway bar in, i did by self and it wasnt to much fun, so it is a good idea to have a buddy there.
Old Aug 22, 2010 | 11:30 AM
ASR subframe brace/ 24mm sway bar combo, on function 7 lca, and beaks tie bar, my rear chassis is basicaly done, im on my way to the front, getting front sway bar, 3 point tower strut bar, and a front lower tie bar,
Old Aug 22, 2010 | 11:31 AM
yea sucks not having a personal car lift
Old Aug 22, 2010 | 12:53 PM
98civdx's Avatar
Master Detailer
your setup sounds good.
It wasnt so much that, it was just moving the bar around, trying to keep it up and tighten the d brackets at the same time. It took a me a few hours, becasue i stopped a few times, it was hot and it was pissing me off. My car is a auto and i couldnt figure out how to get that damn cable out, so i had to wiggle the bar around it, not much fun. It was a 99-00 si sway bar and got started to get really heavy after a while.
Old Aug 22, 2010 | 09:32 PM
yea its pretty good setup i just fixed my toe and allignment so everthings set nice
Old Aug 22, 2010 | 10:57 PM
bluebomber's Avatar
Information Leafblower
Sounds like a nice setup. I'd recommend against a front lower tie bar, in favor of an H-brace instead. I've used both pieces, and the H-brace I got from NRG had better steering response and better ground clearance.
modifiedrocket
Suspension & Brakes
21
Aug 5, 2010 05:57 PM
MattNYC
Jan 22, 2010 10:18 AM
SpdGs2
Suspension & Brakes
Jul 24, 2009 07:47 AM
User 12720
Suspension & Brakes
Jan 10, 2009 04:20 PM
-Whitey-
Nov 8, 2002 08:07 PM
