no vtec after swap im lost
Old Aug 21, 2010 | 04:00 PM
0ldsk00lef's Avatar
Default no vtec after swap im lost
so i have a 95 civic ex coupe. i just put an obd1 b16 in it. everything works fine except vtec. it throws a code 22 for the pressure switch.
things i have tried:
Vtec pressure switch
Vtec solenoid
New oil pump with new oil
Different vtec ecu
checked wires going to the pressure switch. they are good.
i dont know what else would make vtec not work. im at a loss for ideas. any help would be greatly appreciated. thanks.
Old Aug 21, 2010 | 04:52 PM
-__-'s Avatar
Default Re: no vtec after swap im lost
uhh are u using an OEM VTEC solenoid? cuz i think JDM motors don't use oil pressure switches. also did u try running a JDM ECU?
Old Aug 22, 2010 | 05:56 PM
0ldsk00lef's Avatar
I used the solenoid that came with the motor and a different one I had laying around. They both had pressure switches on them and I don't have acces to a jdm ecu
Old Aug 22, 2010 | 06:36 PM
skuded's Avatar
is your speedo working? if not there's your problem
Old Aug 22, 2010 | 06:38 PM
bks84's Avatar
Loved
Did you re-use your stock engine harness?
Old Aug 22, 2010 | 06:42 PM
0ldsk00lef's Avatar
Everything works except vtec. I have a 94 gsr harness that I'm using. Car had a gsr motor in it before and vtec worked
Old Aug 22, 2010 | 06:47 PM
bks84's Avatar
Loved
https://honda-tech.com/forums/tech-misc-15/vtec-troubleshooting-164863/
http://www.superhonda.com/forum/f13/...lenoid-342343/
https://honda-tech.com/forums/honda-prelude-4/official-%22why-vtec-doesnt-engage%22-thread-830163/
Aside from the code 22, any other CEL's?
Old Aug 22, 2010 | 06:59 PM
0ldsk00lef's Avatar
Nope that's the only code
Old Aug 22, 2010 | 07:00 PM
raidacaipo's Avatar
JDM ECU does not look for a vtec pressure switch.
USDM ECU looks for a vtec pressure switch.
3 ways to fix this.
1. Replace the JDM vtec solenoid with a usdm vtec solenoid that has the pressure switch.
2. Replace the USDM ECU to a JDM ECU.
3. Do this quick fix. http://www.phearable.net/tech/wiring/vtpsbypass.gif
I would prefer option 3 first if your on a budget. Guaranteed to work! Make sure you unplug the battery before you do this and reset the ecu once your done so the CEL goes away.
Old Aug 22, 2010 | 07:19 PM
Eaglekper0046's Avatar
3 ways to fix this.
Odd because my JDM ecu did
Old Aug 22, 2010 | 07:50 PM
raidacaipo's Avatar
No it didn't. You probably thought your ecu was jdm when it was usdm.
Old Aug 22, 2010 | 07:57 PM
hoga113's Avatar
Replace the gasket, check is there vacuum leak, I just replace my brake booster just for that last week, weeeiirrd.
Old Aug 22, 2010 | 08:35 PM
raidacaipo's Avatar
Why would he replace the gasket? and what gasket are you talking about? brake booster has nothing to do with the CEL 22 code which is vtec pressure switch code. A vacuum leak doesn't cause that either.
Old Aug 23, 2010 | 01:32 AM
bks84's Avatar
Loved
Whats the code/serial on your ECU?
Old Aug 23, 2010 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
troubleshoot it the honda way
Old Aug 23, 2010 | 07:58 AM
0ldsk00lef's Avatar
i am using a usdm vtec solenoid and the code on my ecu is p72 94 gsr
Old Aug 23, 2010 | 12:34 PM
ricky00's Avatar
u should try it with a different ecu especially with that harness.. let me guess u have like 6 extra plugs thats not plug in right?? that p72 is look for those plugs since the gsr intake manifold is different and has more sensor on it
Old Aug 23, 2010 | 12:35 PM
raidacaipo's Avatar
Did you do the vtec pressure switch bypass trick as I mentioned above? this is a common problem believe it or not and I must have answered 100 of these types of questions because they are easily solved and its nothing new... its an age old question after a swap youll hear over and over again
Old Aug 23, 2010 | 12:41 PM
raidacaipo's Avatar
Only way to tell if your ecu is jdm or not.
example-
USDM ECU 37820-P72-A05
JDM ECU 37820-P72-005
Did you catch that? USDM ECU has a letter after p72. JDM ECU's have numbers instead. FYI that is the number zero and not the letter O
Old Aug 23, 2010 | 12:49 PM
bks84's Avatar
Loved
Im curious to know whats causing it...
Im also curious why you're using a GSR harness and ECU on a B16?
Old Aug 23, 2010 | 01:14 PM
raidacaipo's Avatar
Hes using a gsr harness because it has all the necessary components in order to make a vtec motor work. All integra harness will work with 92-95 civic motors. It doesn't matter if he uses a gsr harness on a non gsr motor.
Are you serious? you been a member since 05 and you can't understand that a usdm ecu looks for the pressure switch when a jdm ecu doesnt? Its so simple people.
EVERYONE READ WHAT I ALREADY POSTED ABOVE, POST #9
Old Aug 23, 2010 | 01:20 PM
egsleepercivic's Avatar
obd1 jdm b16a have a vtec pressure switches, I don't believe they got rid of it until obd 2
at least my JDM b16a does
Old Aug 23, 2010 | 01:23 PM
bks84's Avatar
Loved
wow, you're a lil high on your horse, arent ya? we're all here attempting to help the guy. no need to get fussy. annnnd my buddies OBD0 b16 had a pressure switch as did another of my friends obd1 GSR swap.
i might have been a member since 05, but that has little to do with the scenario at hand. for all my swaps I've used the correct ECU. for example in my personal car, I used a del sol vtec engine harness and usdm p30 ECU on my b16a3 swap. once started I got a KS code, ran wire from shock tower plug to ECU and fixed that.
no need to get snippy and talk down to people. i personally would not use a gsr ecu on a b16 w/o it being chipped/socketed/tuned. thats me though.
Old Aug 23, 2010 | 01:24 PM
raidacaipo's Avatar
What ecu are you using and your saying that your head has a vtec pressure switch on it and its a jdm head?
raidacaipo's Avatar
If your trying to help him then dont post anything if you dont know what your talking about. Your not helping out at all
Why would you ask a question such as:
I have nothing else to say after reading that... it speaks for itself regarding your experience
