adjusting idle?
Old Aug 21, 2010 | 03:39 PM
powerstrokeaaro's Avatar
Default adjusting idle?
my car recently failed smog for idle being to high. I printed out the adjustment procedure from alldata and I have the adjustment screw all the way out and the idle is still at 800-850rpm. It is supposed to be at 420 with the IAC unplugged. Any ideas?
Old Aug 21, 2010 | 03:52 PM
crvtectim's Avatar
Default Re: adjusting idle?
Turn the screw the other way?!?1
Old Aug 21, 2010 | 09:11 PM
no that turns it up lol
Old Aug 22, 2010 | 04:20 AM
Former User's Avatar
Check whether your throttle cable is adjusted too tightly. There should be about 1/2" of slack.
Clean the throttle body if the throttle plate is sticking open.
Check for a vacuum hose leak or an intake air leak from the IM or TB gasket.
crxnonvtec
22
Sep 3, 2009 02:52 PM
h-o-n-d-a
Aug 3, 2009 05:15 PM
emooheo
Mar 23, 2007 02:34 PM
FlatLineEG8
Mar 4, 2004 04:47 PM
Shft@9GSR
Nov 15, 2002 11:21 AM
