HALP! swap crisis - won't start
Old Aug 21, 2010 | 07:41 AM
Kaitosenin's Avatar
Default HALP! swap crisis - won't start
did a swap with another y7 in my 97 ek hatch yet now no cel comes on i hear the fuel pump priming it cranks but doesnt start what did i do wrong?
Old Aug 21, 2010 | 07:51 AM
djblingbling1's Avatar
Default Re: HALP! swap crisis
Are you getting spark? Check for fuel, check for spark, and go from there.
Old Aug 21, 2010 | 07:52 AM
Kaitosenin's Avatar
my bad the fuel pump is NOT priming
Old Aug 21, 2010 | 08:41 AM
b18c_Ek101's Avatar
Double check all the harness and grounds. make sure that all the grounds are clean.
Old Aug 24, 2010 | 08:30 PM
Kaitosenin's Avatar
okay now im getting fuel however im not getting a response from main relay or ecu
anything im doing wrong maybe?
Old Aug 24, 2010 | 09:06 PM
-__-'s Avatar
check ALL grounds and fuses. hope ur battery doesn't die.
Old Aug 25, 2010 | 10:48 PM
Kaitosenin's Avatar
Default Re: HALP! swap crisis - won't start
im curious as this matter, being that during the swap only the negative terminal was removed the negative terminal at one point slid and hit metal I had heard a pop however the fuses were fine it seems as though my grounds are fine as well but perhaps there is a fried ground or perhaps a fried power? or worst case scenario ecu is KIA or main relay?
Old Aug 26, 2010 | 05:45 AM
ludesrv's Avatar
Sounds like a bad ground and what you did was cause the relays to click in and out. When relays are to be on (ignition on) and grounds are bad, they won't 'click' or pull in. When the ground is good, they click in. Fix your grounds and it should start.
The starter ground is the large one in front of the tranny.
The thermostat ground is the main ground for most of your sensors (more important then people think). A bad thermostat ground can cause a car to not run, or run like ****. My EF civic had to have an extension ground added from the thermostat to the negative battery terminal just to start. Before I added it, the relays would pulse in and out when I tried to crank over.
Old Aug 26, 2010 | 06:13 AM
EE_Chris's Avatar
Since the ECU is what controls the main relay which in turn powers your fuel pump, and you're getting fuel, what exactly do you mean by "no response from the main relay or ecu"?
Old Aug 27, 2010 | 01:57 PM
Kaitosenin's Avatar
situation resolved ty ludesrv and everyone for their help it was the ground on the thermostat it was loose lol thanks again
Old Aug 27, 2010 | 02:00 PM
-__-'s Avatar
congrats. and i don't get credit? lol. check this out...
Old Aug 27, 2010 | 04:20 PM
Kaitosenin's Avatar
ty -____-
Old Aug 29, 2010 | 09:23 AM
Kaitosenin's Avatar
hey another issue has revealed itself, after i release the gas the cluster dims somewhat and after the swap my radio cuts in and out any ideas?
Old Aug 30, 2010 | 01:21 PM
b18c_Ek101's Avatar
you cluster probably dims because your altenator was on its way out. but when you did swap did you get a new or different altenator? and as for your radio is it like your losing signal or is the deck shuting off and on?
Old Aug 30, 2010 | 04:25 PM
Kaitosenin's Avatar
same alt,but when i tested it before the alt was good, the deck shuts completely off but im thinking the issue with the deck is a bad ground but idk i may need to retrace the wires coming from the radio harness and see but im thinking your right about the alternator its possible it went to crap after the swap
Josh_Hoskins
Jun 21, 2011 07:26 AM
ChilBlu92
14
Jul 30, 2009 08:30 PM
boostng r
Sep 11, 2004 03:16 AM
mrduque
Jun 13, 2002 12:22 AM
mrduque
Jun 12, 2002 09:44 PM
