cutting out at 7500 rpm's
Old Aug 20, 2010 | 08:40 AM
CivicSi95's Avatar
Default cutting out at 7500 rpm's
i have a jdm b16a and my car is cutting out once i hit about 7500 rpms. its like its hitting the rev limiter and shutting it down. i just had my oil changed the other day and the oil level is full. i also changed out my speed sensor yesterday because i was having speedometer problems. i was hoping changing out the speed sensor would have fixed both problems but it didnt. today, i will be replacing the fuel filter, spark plugs, and plug wires. any ideas or suggestions to whats wrong?
Old Aug 20, 2010 | 08:49 AM
EsotericImage's Avatar
Retired Moderator
Default Re: cutting out at 7500 rpm's
is it a stock ECU?
Old Aug 20, 2010 | 08:56 AM
BigAnteg's Avatar
sounds like a single cam ecu
Old Aug 20, 2010 | 09:52 AM
CivicSi95's Avatar
no, its a p30. ive had this swap up and running fine for about 2 years. this issue just started happening lately
Old Aug 20, 2010 | 09:56 AM
AGENT_47's Avatar
Weird, I had speedo problems to before my ECU went bunk.
Any CEL codes?
Old Aug 20, 2010 | 11:33 AM
CivicSi95's Avatar
no CEL codes
Old Aug 21, 2010 | 11:01 AM
CivicSi95's Avatar
could it be a bad distributor?
Old Aug 21, 2010 | 11:32 AM
b20hatchek's Avatar
that almost sounds like a wiring problem
Old Aug 21, 2010 | 11:44 AM
CivicSi95's Avatar
its weird cause the car has been running perfectly ever since i did the swap. all the sudden im having the electrical issues
Old Aug 21, 2010 | 11:47 AM
Retired Moderator
try a buddies/someones ECU for a B16 and see if it does it with theirs.. that would be a good place to start.
ECU's do take a **** from time to time.
Old Aug 22, 2010 | 10:25 AM
surefeelsgood's Avatar
sounds silly but did you put decent fuel in it.
i put cheap 97 ron in to get home once, and the car kept hesistating at the rpm you are describing. i eased off for fear of deteonation.
put some nice 99 ron in it and it ran fine. sorry forgot to add mines b16 jdm also.
Old Aug 22, 2010 | 10:37 AM
CivicSi95's Avatar
sometimes vtec isnt kicking in clear up to 6-7k rpms then it will kick in. sometimes it kicks in and runs good all the way up to 8k rpms with no sputtering or bogging at all. its really random the way my car is running right now.
Old Aug 22, 2010 | 10:41 AM
bluejcivic's Avatar
check the wires on your vss sensor, i had the exact same problem
Old Aug 23, 2010 | 06:20 AM
CivicSi95's Avatar
what was wrong with your vss sensor wires? mine look like they are good and they are still in the plastic sleeving
Old Aug 23, 2010 | 06:36 AM
mr_munro's Avatar
bad vss
Old Aug 23, 2010 | 07:00 AM
CivicSi95's Avatar
Originally Posted by mr_munro
bad vss
i changed out the vss and the speedometer was still going crazy. maybe not as much but it still was every once in a while
Old Aug 23, 2010 | 11:48 AM
chanek's Avatar
Must be your oil pump pressure, mine does the same. My vtec works then when hit like 7k to 7.5k on 3rd gear then vtec stop working. After changing oil pump, its working fine after all.
Old Aug 23, 2010 | 12:00 PM
CivicSi95's Avatar
everyone is saying something completely different. i guess the only thing to do is start replacing parts and see what eventually solves the problem.
Old Aug 23, 2010 | 01:44 PM
Scott53092's Avatar
did you check your vtec fluid level?
Old Aug 23, 2010 | 01:54 PM
BrandonR's Avatar
No, don't waste your money. Start with a tune-up. A worn rotor and distributor cap can cause this. -Later, BR
mmmbarp
Dec 5, 2010 01:30 PM
andyt
Feb 20, 2007 06:08 PM
solswap
Oct 17, 2002 01:26 PM
shiithook
13
Apr 30, 2002 06:43 PM
