When should I change stock injectors?
Old Sep 17, 2002 | 11:05 AM
myNAteq's Avatar
New User
Default When should I change stock injectors?
Ok...have any of you changed your stock 240cc injectors and are making roughly 190whp. I read a previous post about the stock injectors maxing out on a b17 at 7500 with a an ITR IM and header. I personally am about to drop in a built LS/VTEC into my DA with GSR cams for now, then upgrade to Skunk2 stage 2. What are your opinions as far as fuel delivery. I trust the ITR forum more for advice
Old Sep 17, 2002 | 12:12 PM
guyuenvy's Avatar
Default Re: When should I change stock injectors? (myNAteq)
I would say some 97 up prelude injectors or 310's
Old Sep 17, 2002 | 12:16 PM
uNF$@#!'s Avatar
Default Re: When should I change stock injectors? (guyuenvy)
i'd get 450'ccs and some engine management
Old Sep 17, 2002 | 12:21 PM
MK Ultra's Avatar
It was my friend who was maxing out his injectors. He is both an Acura tech and a Hondata dealer.
We saw a/f ratios as high as 17:1 at 8000+ RPM! Yikes!
EDIT: His advice to anyone with a 1.8 litre is to replace the injectors and put in a Hondata as soon as you start adding mods that increase airflow. He's been saying that the stock injectors are insufficient for a while now, and after seeing this I have to agree.
[Modified by MK Ultra, 3:27 PM 9/17/2002]
Old Sep 17, 2002 | 12:26 PM
Austin's Avatar
Default Re: When should I change stock injectors? (MK Ultra)
I have an I/H/E and Hondata...we were at 100%+ injector duty cycle...just got myself some '97+ Prelude injectors.
Austin
Old Sep 17, 2002 | 12:38 PM
vtec.dc2's Avatar
my stock 240's were running 100% at 8500RPM on stock motor.
one way is to up the fuel pressure - but that would only work to a certain point.. i read before it has some negative effects.
I got 370's and running lower pressure, you would need a good engine managment system to run these.
TokuiAutowerks
Jun 19, 2008 06:02 PM
mdj_ge
Jun 24, 2005 01:21 PM
96redgsr
Jul 21, 2004 09:46 PM
blykins
31
May 4, 2004 06:41 AM
Twigster311
Apr 30, 2003 03:54 PM
