Re-welding open manifold to divided
Is it possible to re-weld a mild steel tubular manifold to make it a divided manifold? I have a very nice mild steel equal length manifold I'd like to have a welder to work on. Primarily add a piece of steel in the collector to divide the runners and weld on the proper divided flange.
Not 100% ideal, but I think it may be worth it if it can provide the desired results. And would be hella cheaper than a "quick spool" valve. Not sure I like the idea of that valve anyway.
They do pair properly already....
Right now I get 25psi at about 5000 rpm. Precision 6062 turbo. If it gets me 250 rpm of spool I'd be thrilled.
