Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
HIDS AND DRL QUESTION
Old Aug 19, 2010 | 07:26 AM
ch3xy's Avatar
Default HIDS AND DRL QUESTION
Ok so my hid kit comes in tomorrow and i'm looking forward to installing it. my question now is what about my daytime running lights? im going to be tri-colored at night? my DRL, lows and corners are all going to be different colors?
are there hid kits for the DRLs?
Old Aug 19, 2010 | 07:57 AM
ajpturbopittsburgh's Avatar
Default Re: HIDS AND DRL QUESTION
Your daytime running lights are just your low beams running on low voltage I think. So when you have your low beams on at night there is no DRL. Also I have the ddm tuning HID's and after you install your kit the ballast must interrupt the low voltage signal for you DRL and they wont work and you will get a light on your dash that says DRL telling you that there is a problem.
The ballast for your HID steps up the voltage and the low voltage for your DRL must not be enough to turn on the lights.
Old Aug 19, 2010 | 08:14 AM
ch3xy's Avatar
ok so what do i do with the DLRs? how do i get the msg off of my dash?
Old Aug 19, 2010 | 08:47 AM
^Nothing because they won't work anymore. I don't think you can get the light off your dash.
Old Aug 19, 2010 | 09:45 AM
ch3xy's Avatar
awww man, that lights going to drive me nutts
Old Aug 19, 2010 | 01:34 PM
av911's Avatar
The DRLs are your high beams (9005), not lows (9006).
When you turn on your headlights (low), your DRLs will be OFF, don't know how you'd get "tri color" at night, unless you turn on your highs or wired your DRLs to turn on.
Old Aug 19, 2010 | 01:39 PM
2008fijibluesi's Avatar
Pull the DRL fuse and you won't have to worry about the DRL light
Old Aug 20, 2010 | 04:32 PM
vladd's Avatar
x2. read the chart in the owner's manual, it'll tell you what fuse to pull. the chart might also be on the fuse box cover, don't remember.
Old Aug 20, 2010 | 05:00 PM
hiphopsi's Avatar
Old Aug 27, 2010 | 09:29 PM
Canuck99's Avatar
There is a DRL fuse 7.5 A under dash fuse box, never pulled one out will have to see what happens...According to the wireing diagram it shows not used...The DRL is part of The MICU now and sends reduced volage to the high beams once it sees vehical ign on and parking brake off.
Old Aug 28, 2010 | 01:38 AM
av911's Avatar
The DRL fuse is #37, it is used.
By pulling the fuse, nothing is gonna happen besides disabling the DRLs.
Old Aug 28, 2010 | 03:48 PM
SIck1's Avatar
Your lows (9006) are seperate from everything. Your highs are the drls at higher voltage. The only time you will see three lights is when you have your highs on. If you bought 6k like I did it isn't noticeable.
Old Sep 2, 2010 | 03:06 AM
Kidnkorner's Avatar
You not going to rock a plug and ghey HID set-up, are you?
cadwiese
11
Jan 10, 2013 06:58 PM
bluebomber
Lighting
Aug 15, 2009 04:33 AM
TypeRvtec18
Jan 21, 2003 08:19 PM
DC2ITR
Apr 7, 2002 06:04 PM
CheezeFrog
Aug 8, 2001 03:27 PM
