Boring stock head gasket for use with larger bores?
Old Sep 17, 2002 | 10:22 AM
boomslang's Avatar
Default Boring stock head gasket for use with larger bores?
I measured a stock CRV headgasket and the bores measure ~84.80mm. I am assuming this is because it gets squished in a little when you tighten the head.
So if I wanted to use a bored CRV gasket with 85mm bores, would I want to bore the gasket to 85.80mm?
Old Sep 17, 2002 | 06:20 PM
boomslang's Avatar
Default Re: Boring stock head gasket for use with larger bores? (Inlinefour)
up up up
Old Sep 17, 2002 | 08:07 PM
TREVER's Avatar
buy a cometic 85
boring stock gaskets is not as reliable as a gasket made for your bore.
Old Sep 18, 2002 | 05:09 AM
boomslang's Avatar
Default Re: Boring stock head gasket for use with larger bores? (TREVER)
Come on guys, I know some of you have done this.
Old Sep 18, 2002 | 05:16 AM
newsense's Avatar
New User
i agree with him why not just buy the Cometic... at least for piece of mind. You dont want to skimp when it comes to a build up.
MiraiZ's Avatar
thqat sounds crazy and ghetto...just get a new one..
Old Sep 18, 2002 | 05:30 AM
boomslang's Avatar
Default Re: Boring stock head gasket for use with larger bores? (newsense)
I am not skimping on anything. I could care less about the price. Many guys recommend using stock headgaskets, even on high power cars.
fyi: I already have a cometic gasket.
Old Sep 18, 2002 | 05:44 AM
newspeedR's Avatar
from what i have heard, Golden Eagle custom bores stock gaskets... So you should be able to do it with out a problem
Old Sep 18, 2002 | 06:19 AM
boomslang's Avatar
Default Re: Boring stock head gasket for use with larger bores? (newspeedR)
Yeah, the question is how much needs to be taken out?
Old Sep 18, 2002 | 06:43 AM
sgT's Avatar
sgT
Just use the CRV head gasket as is.
Old Sep 18, 2002 | 06:57 AM
boomslang's Avatar
Default Re: Boring stock head gasket for use with larger bores? (sgT)
Even for 85mm pistons?
The gasket will protrude into the combustion chamber and might be hit by the pistons.
Old Sep 18, 2002 | 07:11 AM
Ri5e's Avatar
*Pulls out scissors*
Old Sep 18, 2002 | 08:20 AM
dbman96's Avatar
New User
The gasket should only be hit by the pistons if you lose a connecting rod bolt or bearing.
Old Sep 18, 2002 | 08:41 AM
Sonny's Avatar
Default Re: Boring stock head gasket for use with larger bores? (MiraiZ)
Sonny
Old Sep 18, 2002 | 09:31 AM
sgT's Avatar
sgT
It will not. Trust me.
Old Sep 18, 2002 | 12:00 PM
austrian type-R's Avatar
Default Re: Boring stock head gasket for use with larger bores? (dbman96)
owned
Old Sep 18, 2002 | 12:21 PM
apexii's Avatar
Default Re: Boring stock head gasket for use with larger bores? (austrian type-R)
This is a valid question, nobody has really answered it yet either. I have the same concern. I have an 89mm bore in my h22. There are no 89mm oem gaskets. I thought GE reccomends to use an oem with their copper o-ring, which is what I have. So what are my choices?
Old Sep 18, 2002 | 12:48 PM
sgT's Avatar
sgT
Default Re: Boring stock head gasket for use with larger bores? (apexii)
Give cometic a call and they can make you a gasket with any bore you need.
K20 EG
May 8, 2003 09:49 AM
schwett
Apr 18, 2002 04:19 PM
paulzy
Nov 8, 2001 12:21 AM
therealnapster
Sep 10, 2001 01:32 PM
therealnapster
Sep 9, 2001 08:07 PM
