car been dead for 3 days...NEED HELP
Old Aug 18, 2010 | 04:07 PM
thedao's Avatar
Default car been dead for 3 days...NEED HELP
o.k so i drove my car (93 civic coupe with b16 swap) that morning and everything was fine.. later on that night when I tried to start the car up it sounded like it turned turned over for a split second then it just went dead... car dose not click or crank over nothing. all the light and power options still works so it not the batteries. checked the starter on another car, and car started up just like that. all the wiring seems good. the only thing i can think up right now would be the dizzy... but just want your guys thought about this....
Old Aug 18, 2010 | 04:13 PM
H23_del_soul's Avatar
Default Re: car been dead for 3 days...NEED HELP
Sounds like a solenoid, you might have bumped it enough to make it work when you swapped it.
Old Aug 18, 2010 | 04:15 PM
EJeff8's Avatar
When starters go bad, you can smack them with a hammer and crap and they'll engage next time you try. It won't last long though, you'll crack the magnet soon enough.
Like Delsol said, bad starter.
Old Aug 18, 2010 | 05:04 PM
Former User's Avatar
Did the rubber stopper that presses on the clutch pedal safety switch break or fall out?
Old Aug 18, 2010 | 07:15 PM
thedao's Avatar
I dont think it would be the starter, because i took mine out and swap it with my cousin gsr. his car started up.
Old Aug 18, 2010 | 07:17 PM
Old Aug 18, 2010 | 07:30 PM
D16SiHatch's Avatar
if not that ^ then check to make sure you don't have a loose connection at the starter or at the battery.
Old Aug 18, 2010 | 09:25 PM
WeakSauce92's Avatar
definitely starter or the rubber stopper..
Old Aug 18, 2010 | 09:36 PM
crvtectim's Avatar
I think RonJ@HT nailed it, but I'll share a tip with you anyways. To check for a good connection at the battery, turn your key on, headlights on, turn the battery terminals until your headlights come on. Then try to start the car. One other thing, if your ground wire from the valve cover to the core support has a bad connection, your car will not start.
Old Aug 19, 2010 | 06:09 AM
thedao's Avatar
Alright ill take a look at it and update thanks for the tip guys..
Old Aug 19, 2010 | 01:33 PM
B Dap's Avatar
Cant get my car to start right now either Dao, **** sucks...
Old Aug 20, 2010 | 10:38 PM
ehinoeg6's Avatar
could be a wire that is connected to the alternator that makes it charge.
i had the same problem,my alternator wasnt generating the 2volts that it needs,so i was driving on just battery power until it lost voltage.
took the alternator to a local auto zone.
they said it was good.
my friend did a electrical test.and find out one of the wires wasnt letting it charge,bad connection.
toolfan020
12
Dec 9, 2011 07:42 AM
c00ker
Honda Civic (2001 - 2005)
Jun 23, 2011 06:45 PM
everlight44
Feb 7, 2009 11:35 AM
CUTTERSPOOL
Feb 1, 2009 04:53 PM
EJ8ronnie
Oct 29, 2007 04:14 PM
