transmission help!!!! B16 cable
Old Aug 18, 2010 | 10:12 AM
kali.eg6's Avatar
Icon2 transmission help!!!! B16 cable
i have a b16 cable with a hole on the casing
either i need to replace it or i was wondering if i can use those internals and put it into a hydro casing?? thus making "cable to hydro"
if anyone has a casing for sale le tme know please!!!!
Old Aug 18, 2010 | 10:40 AM
Ron454321's Avatar
Default Re: transmission help!!!! B16 cable
What caused the hole in the casing? If it was the internals then why swap them over? And I take it you did a cable to hydro swap already, if so it might be time to just go for a hydro unit.
Old Aug 18, 2010 | 11:11 AM
94EG8's Avatar
Seagull Management
Cable B16 trannys as far as I know are all small spline (like '90 - '91 Integras), you can't swap the guts into a hydro case ('92 - '93 Integra YS1 transmissions you can) I presume the hole was caused by the stock diff grenading?
Old Sep 7, 2010 | 11:29 AM
kali.eg6's Avatar
Damage was done while driving, hit a center divider gears seem ok but I also haven't gotten the tie to open it...
pleej
Aug 24, 2010 07:35 AM
PINKS
May 29, 2007 11:47 AM
DraginTeg93
Feb 8, 2007 05:33 PM
soon2b
Jan 21, 2004 09:24 AM
VTECHEART
Apr 5, 2002 11:33 PM
