g23 question
Old Aug 17, 2010 | 04:18 PM
vtechjunkie's Avatar
Default g23 question
Which bottom end and which head work the best. I can get a good deal on a f23a1 right now, and was wondering if it was worth picking up.
Old Aug 18, 2010 | 11:20 AM
Default Re: g23 question
anyone?
Old Aug 18, 2010 | 11:25 AM
noobcake's Avatar
None. Its not an lsvtec. Its useless and unreliable. People have done it and made it work.
And mixing an f and an h doesn't make a g. A g series is a 5 cylinder acura motor.
Old Aug 18, 2010 | 12:03 PM
i've read a thread on putting an h22 head on a f23 bottom end. Maybe ill google it.
Old Aug 18, 2010 | 12:16 PM
92civlude's Avatar
Compression will be 8.8 to 1! Kinda doggy. I used k20a3 pistons for about 10.3 to 1.
Old Aug 18, 2010 | 08:11 PM
On the stock rods? Are those the same bore size as the f23a1?
Old Aug 19, 2010 | 07:19 AM
92civlude's Avatar
The dimensions are the same. But in order to have the same pin offset, Youll have to install the k pistons backwards because The K spins in a diiferent direction than the F. Youll also have to enlarge the exhaust valve reliefs to match the intake valves. If you use aftermarket pistons, none of that will be an issue because they have 0 offset. PirateMcfred is the trailblazer when it comes to the G23. He has a build tread in the Prelude section.
Old Aug 19, 2010 | 09:12 PM
I saw that one, I was thinking about using that as a guide.
SlowK24
K Series
Mar 6, 2018 09:04 PM
90CB7EX
K Series
Nov 16, 2016 07:20 PM
92CHB
Oct 10, 2011 07:36 AM
ashb82
23
Mar 29, 2008 01:33 PM
Hockey27925
Dec 22, 2004 08:11 PM
