d15 tranny on d16???
Old Aug 17, 2010 | 01:52 PM
crxsi361's Avatar
Default d15 tranny on d16???
im doing a d16z6 swap into my dx civic coupe i need to know if my tranny that i have for my d15b7 will be good for it
Old Aug 17, 2010 | 02:02 PM
WeakSauce92's Avatar
Default Re: d15 tranny on d16???
yeah just make sure the output shaft seals are in good condition. also inspect the clutch for damage and just replace the throwout bearing. not sure but you might need to reuse the axles from the d15. It'll work great but you won't really have much power with that tranny. It's the same setup I have now and I recently drove my buddy's hatch with the si tranny and almost cried at the difference lol. good luck
Old Aug 17, 2010 | 02:44 PM
Targa250R's Avatar
be professional
Bolts right up and functions properly, but the gearing sucks.
I'd swap an EX transmission into a DX before I'd bother swapping the engines themselves.
Old Aug 17, 2010 | 04:03 PM
crxsi361's Avatar
well i think i got a ex tranny at my cuz car lot
Old Aug 17, 2010 | 06:37 PM
hugox's Avatar
the dx tranny gear ratio for the 2nd and the 3rd are really close to each other so you wont have much of a pick up when you shift gears. besides that, the tranny is a straight swap. you dont even have to change clutches of nothing.
Old Aug 17, 2010 | 07:09 PM
D16SiHatch's Avatar
not true. the difference between 2nd and 3rd gears is large enough, not to mention the final drive is longer on the dx trans. together you have quite a big difference in gearing.
Old Aug 17, 2010 | 08:01 PM
all in all though, it's nothing great. Honestly, I'd rather have the original z6 tranny and swap out the dx final drive.
Old Aug 18, 2010 | 02:17 PM
crxsi361's Avatar
so just swap out the final drive on my tranny into the z6 tanny
Old Aug 18, 2010 | 02:59 PM
lol if you're confident enough to open up a transmission and do it yourself or spend the money to have someone reliable to do it. do you have the original? does it grind at all?
Old Aug 18, 2010 | 06:10 PM
Targa250R's Avatar
be professional
You could do that, if you want to go slower . . .
Old Aug 18, 2010 | 07:09 PM
crxsi361's Avatar
no grinds at all but another question what is the difference between the d15b jdm vtec and the d16z6 or i think its zc jdm vtec im not sure cause ive seen people say they have the same hp and torque that the only difference is 1.6 liter and 1.5 liter
Old Aug 18, 2010 | 09:17 PM
It's only the final drive.. you still have all the fun of the 1-4 but you can still go on those long night drives and still be at like 3k going 80 but to each his own.
Old Aug 18, 2010 | 09:20 PM
Not really sure but I think the zc is dohc.. and yeah from I can remember the numbers are pretty similar.. hopefully someone more knowledgeable can give you some insight. And like I just posted, putting the d15 final drive will only help with gas mileage.
CRXREFIC
Aug 7, 2009 10:19 AM
Tippyman
Mar 27, 2006 09:08 PM
Bond
13
Mar 15, 2005 02:59 PM
skellator_thoj
Apr 22, 2003 02:52 PM
S13 slide
Sep 6, 2002 12:33 PM
