B16a3 flywheel help
Old Aug 16, 2010 | 09:11 PM
anzh86's Avatar
Default B16a3 flywheel help
I'm working on swapping a b16a3 delsol vtec into my eg. i had to buy a clutch and flywheel, so i got an integra clutch and flywheel. on H-t marketplace, i saw some guy selling a P30 flywheel. i was wondering if my integra flywheel would work or do i need a p30 one?
Thanks
Old Aug 16, 2010 | 09:15 PM
Green Crack's Avatar
Default Re: B16a3 flywheel help
All B series flywheels are the same except for pressure plate bolt quantity.
Old Aug 16, 2010 | 09:24 PM
Deetz's Avatar
Crazy Honda Guy
They all have the same bolt pattern and can be interchanged. The only flywheel that is different is the ITR model, its about 3 lbs lighter
Old Aug 16, 2010 | 09:42 PM
anzh86's Avatar
what's this about a pressure plate bolt quantity? because the clutch came with an integra pressure plate. does that mean i need to get a delsol vtec pressure plate?
Old Aug 16, 2010 | 09:48 PM
Deetz's Avatar
Crazy Honda Guy
dont listen to the quantity BS, they are all the same....the only difference in pressure plates, is the strength on the vtec models is better.....they flywheels are the same as i mentioned earlier!!! The del sol dohc pp will work fine
Old Aug 16, 2010 | 10:24 PM
93h2beg's Avatar
the difference is the gsr CAN use 9 pressure plate bolts, while the b16 only uses 6. you can run the gsr with 6 with NO issues.
Old Aug 16, 2010 | 10:33 PM
Deetz's Avatar
Crazy Honda Guy
?? Like i said, they are interchangable......
http://www.hondapartsdeals.com/hpa/i.../11/799697.png
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
jdmCivic925
Jul 28, 2004 10:11 PM
luderone
Sep 13, 2003 02:01 PM
mattL
Apr 18, 2002 09:39 AM
